Introduction: Emergency Rechargeable Flash
HI! Welcome to my first instructable ever...Today I have brought you a very special flashlight that not only is bright enough to scare ghosts away also extremely portable. You can use this torch in these scenarios like for instance you get stuck in a jungle so the flashlight that is attached to your keys will serve you as very useful. Let's jump right into the project.
You will need a 666 led. A tp4056 module, a lipo batt (a small one would be perfect), a slide switch, a USB female and 2 male connectors and to stick it all together with a power glue. (i used an epoxy glue) Also an aluminium sheet.
Step 1: MAKE THE BASE
Take the aluminium sheet and lay it down as a base of the torch then place the USB and the battery like shown in the image.
Step 2: LIGHT IT UP!
When the glue has dried and the USB and the battery are in place, turn over the torch and stick the light.
Step 3: ADD THE SWITCH
On the other side of the torch A.K.A on the battery stick the switch.
Step 4: THINK
Make the connections as shown in the image.
Step 5: THE CHARGER
Make the charger as shown as in the schematics with the tp4056 and the two USB ports.
Step 6: YES !
It lights up.
