Introduction: Emergency String Hemp Bracelet
Simple hemp bracelet that can be pulled apart easily when you need some string, expanding to 6-7 times its length.
Step 1: The Materials
You'll need some string (either hemp or something else) that's around 6-7x the circumference of your wrist (that might vary depending on the thickness of the string, increase it if you're worried), a small bead, and a pair of scissors or a knife.
Step 2: Start Knotting
I apologize in advance for out of focus images. My camera's auto-focus is broken. I'm using yarn in these pictures to make it easier to see the knot.
Make a loop near one end of the string. Leave 3-4 inches (8-10cm) free at the end. Put your fingers through the loop and pinch the long part of the string. Pull a new loop (horizontal piece in second picture) through your first loop.
Tighten the first loop you made by pulling on the new loop. Make sure you don't pull the free end (orange) through - you want to get a new loop like you see in the third picture.
Repeat the above steps by reaching through the loop and pulling a new loop through it, then tightening the knot. It's just like the first chain you'd make crocheting.
Step 3: Close the Bracelet
When you've knotted enough length that the bracelet wraps comfortably around your wrist, it's time to tie it on. Normally you could just tie the two ends of the string together, but we want the bracelet to come undone easily without untying anything, so we'll need a different way to connect the ends.
Go back to the opposite end of the string (where you started) and make a new knot, as if you were starting the knotting process in the opposite direction. Tighten the knot but don't pull a second loop through, just leave the one loop you just made.
This part is a little awkward, you might need a friend to help hold everything. Put the bracelet around your wrist. Put the loop at the end of the bracelet through the loop at the beginning (the one you just made). Tighten the loop at the beginning (red in pictures). It helps to hold it like in the second picture (the part I'm holding corresponds to green in the pictures).
Step 4: Bead "ripcord"
Tie two more knots on the end of your bracelet (green).
Take the free string from the new loop you made in step 3 (red in the pictures) and feed it through the bead. Feed the string through the last loop of your bracelet (green in the pictures).
Tighten the green loop by pulling on the green string (picture 2). Then pull on the red string. You might have to pull on each of them a few more times to make sure they both are tight (picture 3).
Optional: Tie a regular old knot of your choice on the green string as insurance that when you pull on the bead the correct string (red) comes free.
Step 5: Done!
Wet the bracelet to tighten the knots. Trim off the excess strings, leaving about an 1/8 inch (.3 centimeter) stubs.
When danger strikes and you need string immediately, pull on the bead until it comes off (releasing the red string from the pictures) then pull on the other string (green) until the bracelet comes off. Keep pulling and the whole thing will unravel, giving you about 35 inches (90 cm) of string whenever you need it. Because of the way it's tied around your wrist, pulling on the bracelet itself won't do anything, so it shouldn't fall off during normal wear. If it does, leave bigger stubs next time (and do the optional part of step 4: tie a normal knot on the green string before trimming off the excess).
14 Discussions
11 years ago on Step 5
if you find out what it is called tell me
do you know what the other bracelet your wearing is called?
Reply 11 years ago on Step 5
I don't know what it's called. It's made of copper and I bought it from a small store near my house. I think it was just a local jewelry maker, not a big brand.
The design is very simple though. It looks like it was made from two thick copper wires twisted together then hammered flat.
k thanks
12 years ago on Introduction
hey, thats pretty cool, but I dont think you would use it that often... I keep paracord on me at all times on my key chain, just tied figure 8s on the ends, and folded over 4 times, so it's 8 strands thick (and twisted a little, so its neat). with keys on the looped end, and a carabiner on the looped/figure8 end, it's only a foot long, and I have 10ft of 500 lb strength rope I can use whenever i want.
Reply 12 years ago on Introduction
Thanks. I agree, it's not incredibly useful. I usually have some sort of hemp bracelet on. I figured I might as well knot it so I could use it if I needed it, instead of the usual way that's only there for looks. 10 ft of paracord is definitely more useful. One could make this bracelet so it fit twice around their wrist, which would increase the string length to 6 feet. Still not 500 lb strength, but it could come in handy :-)
As soon as I can get my hands on some paracord I think I will try this bracelet with it! That would be wicked.
Definatly! Thats actually what I was looking for and found this bracelet. If you happen to do a survival bracelet let me know! I'd love to make one but have no idea how to.
I am no knot expert (knotspert?) but, a double slipknot would probably be easier....
It took me a little while to figure out what exactly your instructions meant. Maybe thats just me though. But now that I have a hang of making these I definitely love the design. A great Instructable. But the instructions could be dumbed down a bit for people like me. Lol.
an added bonus is if u r a druggy and run out of mony u stll have hemp
did you know hemp is made out of marijuana? lolz.
Actually, Marijuana is harvested from a certain type of hemp, and most hemp is actually not marijuana-y.
Just to clear it up, Cannibis Sativa and (less commonly) Cannibis Indica are both plants which provide hemp, as well as the "buds" on the plants containing the pyschoactive chemical THC (along with hundreds of others, but this is the main culprit).
