Emergency Fishing Line
Intro: Emergency Fishing Line
With this DIY tool you can easily make very long fishing lines in emergency circumstances. Not only that, you can make a strong plastic wire to wrap wood branches together and build structures, you can easily replace you shoe laces, hang up food to trees during the night, build an hammock, or net to catch wild animals, and much more.
Just think that from a single empty drinking yogurt bottle, which has a surface of about 23 x 16 cm, you can obtain a single thin (1 mm wide) wire 35 m long, very good to catch small fishes. If you wish to have a stronger cable you can cut a 3 mm wide stripe, so to have about 12 m long wire, not bad.
You only need a plastic bottle or container... quite hard to find if you are in the wild, but you could be lucky ;-)
As reference for this project I used a very interesting video found on the web, where a smart Russian guy use this technique to cut a long plastic wire.
STEP 1: Cut the Slots
You need a small piece of metal profile, L or U shaped.
With a metal saw cut three or four slots on one edge as in the picture. These slots have to be of different lengths, so to choose the width of the plastic stripe. You can choose to start from 1 mm and to arrive to 5 mm or more.
My profile is quite short, but this is what I had. Anyway is very handy to keep in a pocket, and it works well.
STEP 2: The Blade
As blade I used a small cutter blade, but you can decide to use a bigger one. Place the blade against the inner edge, then mark the spots where to drill two holes for the bolts. I used a spindle to drill by hand.
STEP 3: The Handle Joint
Fasten the blade with the two bolts. To secure the bar which will keep the bottle I decided to use a threaded cylinder, the type you need to secure the bulb holders in a lamp.
STEP 4: Bend the Profile
This is needed since when I tested my tool I discovered that the blade was inclined to exit from the plastic. This is due to the blade profile: if the blade is flat on one side you don't need it, just place the flat side toward the bottle. if the blade is symmetrical, you need to bend the profile, so that the blade is a bit inclined toward the opposite side of the bottle, as in the picture.
An option here is to use a simple pencil sharpener blade, which is flat on one side. In that way you an avoid to bend the aluminium profile.
STEP 5: Add an Adjustment Rod
Since the prototype didn't work very well, I added a wood rod to modify the distance between bottle axis and slot.
One hollow threaded pipe act as pivot, the other one is where the bottle support is inserted. Note that I added a wider nut between profile and wood, that will keep the wood rod not influenced by the blade grade.
STEP 6: Bottle Support
As bottle support you can use any branch of bar. Since my "wildness" is a busy city I used a pencil. Insert the pencil in the pipe, and move the rod to make the distance from pencil and slot equal to the bottle radius.
STEP 7: Begin Cutting
Start cutting is the most difficult part. If the bottle material is not very thin you should not have problems. Just insert in a slot the edge of the bottle (at which you previously cut the bottom), then push the edge inside the slot until you have enough wire to pull it. Begin pulling the wire paying attention that the bottle doesn't turn away from the tool.
STEP 8: Enjoy and Think Up
If you prefer to keep the tool more comfortably hang it in a bench vise.
Now just think up to new ways to take advantage of this cool tool, actually this is a great way to re-use the plastic garbage which otherwise will cover the oceans (read here!)
22 Comments
Mohammade9 4 years ago
by the way, we shall make this tool first before we go to "emergency" case: survival, camping, etc. :D
Raven Survivor 7 years ago
f1dd13r 8 years ago
I am so glad you did this ible..I saw the russian video a couple of days ago and wasnt sure how the slots were supposed to go. All is now clear.
cleigh6 9 years ago
thanks for a really interesting tutorial...
andrea biffi 9 years ago
you are welcome! I encourage you to make an instructable about coloured bracelets! :-)
dewolfe 9 years ago
I've seen something similar in Brazil where it was used to create "broom straws" from empty two liter bottles. Clamped in simple wooden blocks and with a handle it made gainful employment for disabled people.
that's a great idea, perfect to keep straws together
michaelgc 9 years ago
Cool survival project. Thanks.
fozzy13 9 years ago
I'm so happy that you actually pursued this idea! It looks great!
I'm happy too!
fercarbar 9 years ago
Great idea, to make baskets... congratulations
WOW another great idea to use those plastic ribbons! :D
Danger is my middle name 9 years ago
I've seen people do this before, very cool!
yes this does not come out of my brain this time ;-)
watchmeflyy 9 years ago
Very VERY clever! I've never seen anything like it!
glad you like it!
lindarose92 9 years ago
Ingenious!
grazie :)
grazie :)
technoDr Pardis 9 years ago
Incredible! To usefully recycle an otherwise junk material. As a comment on "step 4" you can avoid this step by using a simple pencil sharpener blade. it's flat on one side. Or if one has grinding tools, the blade can be custom made from a useless hacksaw blade.
