Introduction: Emmet Lego Figure Costume From LEGO MOVIE
My son wanted to be Emmet from LEGO MOVIE for Halloween so I looked all over for the costume @ every retailer imaginable, after I had run out of options I decided that I would try to make his costume at home. The head and hair are just a sheet of dense foam. I cut out many of the needed diameter and glued them all together. after that had died I used a coarse wood file to start shaping the foam to my desired shape. I then coated it in resin and painted it. The whole body is nothing more than precisely cut junk cardboard scraps taped together and covered in resin.
Step 1: Measurements of the Person That Is Going to Be Wearing It Are "key"
First thing you need to do is get some measurements. You want the costume to fit the person you are building it for. You can't expect to build it and just hope they can fit in to it. Get measurements of head, shoulders, chest, mid section, waist, legs, feet, etc.. I took every measurement I made and added one inch to it. That way the costume would fit "snug". I found a flat piece off cardboard and started drawing out my measurements. I decided how wide the waist needed to be to look the most "lego like", then based everything from the waist down off of those measurements. Having a lego figure with you will really help with this step. I drew it out with tabs so that it didn't have gaps on the corners after I cut it out and folded the cardboard.
Step 2: Drawing Out and Cutting Your Foam for the Head.
I got a dense sheet of foam to use for the head and hair. I figured out my measurements by comparing the little lego guys proportions in my hand vs. the mid section that I had just drawn out on the cardboard. To make the circles on the foam you can either use a protractor or the ol' nail on one end of a string and marker on the other end. Depending on your thickness of foam you will need to determine how many circles you will have to cut out to reach your desired height. keep in mind that one of the circles you need to cut out are for the neck so it will be about 2 inches narrower than the others but should be figured in to your overall height. Use either a thin steak knife or an old hack saw blade wrapped in tape like I did to cut out the circles. Make sure to keep your blade squared up with your sheet of foam while cutting out the circles so your circles don't end up having angled edges.
Step 3: Gluing the Circles of Foam Together.
To glue the circles together I found it best to use either wood glue or Loctite G02 Glue (which dries like rubberish foam) First choice would be wood glue though. When you glue the circles together you should line them up as flush as possible and keep the glue back away from the edges about half an inch. Also keep in mind that there will be a head in the middle of this so glue where the head will be is a waste of glue. After glueing them all together including the neck, I flipped them over upside down and found the heaviest object to sit on top of them till they dried. In my case I used a car battery for a weight.
Step 4: After a Day or So Its Time to Shape and Hollow Out the Head
Using a coarse file and 80 grit sand paper I smoothed up the head and curved the edges to make it look more like a lego head. after you're done with shaping its time to add the lego tab to the top of the head. Again I figured out my measurement by comparing the foam head to an actual lego head. After glueing the lego tab on top of the head you'll need to let it dry the same way you did the rest of the head. When it's dry you'll just need to slightly sand and roll the edges of the tab to make it look right. After that I drew my sons head measurements on the bottom of the neck with a marker and started carving out the foam until I reached my desired size. make sure to carve out a little extra for their nose to sit comfortably.
Step 5: Test Fitting the Head and Chest.
Just try it on at this point and make sure it all fits like it should. Now is the time to make changes if needed.
Step 6: Drawing Out, Cutting, and Building the Rest of the Body
To make the legs and crotch (which holds the legs) I used cardboard and a cardboard concrete form for the radius at the top of the legs. Tape it all together and test fit the costume again to make sure they can move around freely in it.
Step 7: Making the Hair.
I forgot to take pictures of this but what I did was set the head out and pretty much made half moon pieces of foam that fit around the head all the way to the top then cut out the pieces like doughnuts to go around the head for the bangs and top of hair then topped it off with a smaller circle. I glued it all together and held it together with toothpicks and wedges till it dried. I then shaped it with my file and sand paper.
Step 8: Covering Everything With Primer.
After everything was were I wanted it I covered all of it in fiberglass resin to give it a rock hard shell then coated all of it with very heavy coats of primer.
Step 9: Painting...
I then very heavily coated everything it's desired color using spray paint. Notice the AMAZING thick shiny finish. You get that from taking your time and applying many many even coats.
Step 10: Detail!!!
The white and blue of the shirt are spray paint that I taped off and sprayed. The reflective stripes are glitter duct tape that I found in the arts and crafts section of a local store. All of the black is Sharpie marker (make sure to get a bunch of brand new markers because they crap out pretty quickly on here) The red and black on the face are Sharpie marker and the white teeth was done with spray paint.
Step 11: You'll Need a Way to See So Determine Where Your Eyes Will Be and Cut It Out With the Saw Blade. in My Case the Look Out Is the Mouth.
Step 12: Enjoy!
Step 13:
Fourth Prize in the
Halloween Costume Contest
Runner Up in the
Superheroes and Supervillains Contest
First Time Author Challenge
63 Comments
Question 3 years ago on Introduction
First of all you are my hero! I am a great costuming mom but i am having a horrible time doing these legos! we are trying to do it for the whole family and getting the proper materials etc is KILLING me and I'm already 3 weeks into the project! Can you help me? How did you cut your eyes out ? I am using a concrete tube for the heads but spray paint looked horrible so i decided to cover them with a stretch fabric that looks great but haven't done the faces yet so wish my luck - working on bodies at the same time but the hair is a huge problem for me! What exactly did you use! I bought foam insulation peeled off the back cut it stacked it glued it but i am nowhere CLOSE to you! Did you use a polystyrene foam! Please help me!
my email is jessicasetford@gmail.com ! any pics or help would be so appreciated!
3 years ago on Step 12
Thanks brother!!! I only did the upper torso of the LEGO body! Followed everything and was PERCECT!! Son and friends were happy for his bday! Pictures were absolutely AMAZING! Thanks again. God Bless.
Question 3 years ago on Step 6
Hi i am curious how exactly you made the belt and legs because i am quite stuck trying to figure how to do this could you please explain more and send me photos please kind regards Tiffany
4 years ago
This is really great! Would love to see a video of it in action! :)
5 years ago
very nice costume :-) loe the plastic glance it gives. very detailed!
6 years ago
Hello how so you apply the fiberglass resin? Could you apply this to paper/cardboard items to stiffen it? Is this water resistant?
6 years ago
Did you keep the tape on the whole time, or did you take it off? Also, did you use fiberglass resin right ontop of the cardboard? Thank you, trying to make this for my son for Halloween.
7 years ago
You put fiberglass resin directly on the foam? Won't that eat through the foam?
7 years ago
When you coated the head with fiberglass resin did you just brush it directly on the foam or did you lay a cloth on the foam and then brushed the fiberglass resin over it? If so does it have to be a specific type of cloth?
7 years ago
the belt is pretty much a T shape that matches the curve of the top of the legs. The legs are actually worn by suspenders which carry the entire weight of the costume in order to keep the legs from dragging the ground. You can contact me via email @ codybrown2003@gmail.com then I can easily send pictures in
7 years ago
I'm having a hard time figuring out the crotch and belt. Could you explain or post pictures of how it all connects?
7 years ago on Introduction
I'm trying to make this but having a hard time sourcing the foam. Any resources online or a foam type/name I can search for?
Reply 7 years ago
You can get the foam in sheets at home depot in the flooring section where the carpet padding is...its polyurethane foam
Reply 7 years ago
Thanks. When you used the fiberglass resin, did you use the cloth to reinforce the fiberglass or just the resin?
Reply 7 years ago
There is no fiberglass on this costume. I used cloth in place of the fiberglass for a smoother finish
Reply 7 years ago
Fiberglass cloth or fabric cloth?
Reply 7 years ago
Sorry for all the questions, its my first time working with resin. So rather than using fiberglass in the resin, I should use something like 3M 499 Fiberglass Cloth with the resin?
7 years ago
What specific brand and type of primer was used for the foam and cardboard before painting? Did it help smooth out any indentations in the foam? Thanks!
8 years ago on Introduction
You mentioned that his vision is through the mouth? Looking at the final photos I see a painted mouth with teeth and tongue. I cannot see any screening used or a cutout in the mouth. Would have like to seen a video of this costume in motion. The legs, hips and torso are seamless which would make leg movement difficult.
Reply 8 years ago
Herei just took this "seamless" photo just for you. Now which parts are seamless???
