Introduction: Ender 3 V3 Se Custom Firmware Upgrade
Hi All,
If you have an Ender 3 v3 Se, you basically have two main firmware,
- Marlin
- Klipper
While Creality's original firmware is based on Marlin, there is no new firmware release after 1.0.6.
Creality has open-sourced their firmware https://github.com/CrealityOfficial/Ender-3V3-SE. One can deep dive and customize the same based on their liking...
In this article, I will share a great repo by Navaismo, this firmware has several new features that I have not seen in any other Marlin implementation
Features
- The 7x7-Mesh for bed leveling
- Linear Advance
- Hosts Commands and Support for Runnout Sensor
- Input Shaping Menu
- Extrusion Flow Item to the Tune Menu
- Mute/Unmute LCD Buzzer to the Prepare Menu
- Improved M600 feature
- Raised Max Temperature Values up to 300 degrees
- Fixed Print Information details for SD Print
- Linear Advance Quick Menu
- Custom Extrusion Menu
Features for Octoprint
- Configure the plugin
- Install Plugin's Dependencies
- Set Correct Baud Rate
- Add GCODE SCRIPTS
- Configure O9000 commands
- Configure The GCODE Preview transmission
- Select the Based Progress Type for the Percentage
- Laptop with internet
- SD card reader
- SD card
Step 1: Prepare
- Before we upgrade to the new firmware, we need to be sure that we are on the latest 1.0.6 from Creality
- Skip the below steps if your LCD and Motherboard are on 1.0.6.
- Goto website https://www.creality.com/pages/download-ender-3-v3-se and download Ender-3 V3 SE_HWCR4NS200320C13_SWV1.0.6_GD303.zip
- LCD Display firmware update:
- Format the MicroSD card on the computer side, and select 4096 for the allocation unit size.
- Put the file "TJC_SET" into the MicroSD card.
- Turn off the printer and Insert the MicroSD card into the card slot on the left side of the screen.
- Reboot and wait for the update to finish.
- After finishing the update, remove the TF card and delete the files inside.
- Mainboard firmware update:
- Format the SD card on the computer side, and select 4096 for the allocation unit size.
- Put the firmware file "Ender-3 V3 SE_HWCR4NS200320C13_SWV1.0.6_GD303_20230915.bin" into the root directory of SD card.
- Rename the Ender-3 V3 SE_HWCR4NS200320C13_SWV1.0.6_GD303_20230915.bin to 1.0.6.bin
- Turn off the printer and insert the SD card into the card slot on the motherboard.
- After finishing the update, remove the SD card from the motherboard slot and delete the bin file inside.
- Reference video https://www.crealitycloud.com/post-detail/64f6eb69452e2aea14e70dde
Step 2: New Firmware
- Goto https://github.com/navaismo/Ender-3V3-SE/tree/main/Firmware
- Download the latest, I typically choose 128Kbps file
- All are these are for Octoprint, as well. and works fine as a standalone too.
- Download the zip file and extract
- Rename the file to 1.0.9.7.9d.bin and paste it on a formatted SD card
- Note we do not need to update LCD firmware.
Step 3: Upgrading
- There should be no other file on the SD card.
- Before you upgrade, note the old firmware version
- Wait for 5 minutes before you start the printer and insert the SD with Firmware
- After boot, check the firmware version has changed to new version
Step 4: Conclusion
You also have option to fine-tune the config files to your needs... there are tons of tutorial on the topic.
Hope you liked this article and share any feed backs
