Introduction: Endurance MakeBlock Engraving/cutting Machine. Plotter Kit Transformation
MakeBlock XY plotter is really good thing to use for engraving and laser cutting because it has bigger sizes comparing to DIY kit. 31 X 39 cm (is quite a lot)
General features:
Aluminum extrusion parts. Two Metal stepper motor with back shaft. 12V Solenoid include. Closed type bushing block and ball bushing insert for use in linear motion applications. Four-bolt aluminum alloy bushing block for a lightweight ready-to-mount installation. Synthetic resin retainer plate for accurate ball guidance and low noise. Four rows of recirculating balls inside the ball bushing for smooth running. Integral lip seals to retain lubricant and protect against contamination. Round steel shaft for use with slide units in linear motion applications. Chrome plated for corrosion resistance. Case hardened for wear resistance. Precision ground for consistent ball bushing radial clearance. Software Controlled by mDraw or Benbox, Laser Engraver Upgrade Pack is able to engrave awesome patterns and words on phone case, wallet, jeans, wooden board, paper board, Acrylic plate, etc, hence customizing your own special items.
Engraving graphic display Laser Engraver Upgrade Pack uses a beam of light to cut, engrave, and shape designs from a variety of materials.
Engraver to control the laser engraver robot to engrave fabulous artworks. Cutting of variety of materials:
wood, acrylic, PLA, ABS, felt, fabric, paper, cardboard, hardboard. Has PWM controller. Handiness. Cheapness. Excellent efficacy (40%). Durability and failsafety. New experience of engraving. Made in the USA (tested in Russia). High Quality Control.
Laser Specifications
Endurance L-Cheapo laser (2100mW / 3500 mW)Wavelength 445nmW/ Voltage Conversion Box Input DC 12V 2AOperating Temperature 0℃-50℃Storage & Transport temperature -40℃-85℃Engrave Accuracy 0.1mmEngraver Software mDraw & BenboxBenbox Supports file type JPG, PNG, BMP, GIF, DXFmDraw Supports file type SVG, BMPElectronics Makeblock Me Orion(Based on Arduino Uno)Frame features: Strong aluminum extrusion parts, anodizing surfaceDual-way transmission mechanismImproved pen rising mechanismSuper easy-use stepper motor driver, A4988Updated main board — Me Orion(Base on Arduino UNO)Easy-Controlled by mDrawFrame specification: Physical Dimensions (L×W×H): 620mm × 620mm×140mmWorking area (X×Y): 310mm×390mmG.W.: 4.3kg
