Introduction: Engineering Assignment
this is a inscrutable for a engineer class where we needed to design an automaton the design is a bird flapping its wings up and down
3/4 inch thick wood
plywood
2 Dowels
wire
webbing
Wood glue and epoxy
a pole
Popsicle sticks
Screws
Step 1: Cut Out the Parts of the Bird
use the image in the photo above to draw out the outline of the bird on some plywood then cut out the outline using a saw
Step 2: Cutting the Body
using an miter saw cut the 3/4 inch board in to 2 9 inch boards and 2 5 inch board
cut the pole in to 3 1 inch long parts but it is recommended to cut out more
finally cut one of the dowels in to one 12 inch segment
Step 3: Making the Cam Shaft
take the 1 inch long segments of the pole and find the center of the segment
now using an drill press drill a hole the size of the dowel cut earlier
using a slightly bigger drill bit drill a hole thew the 5 inch boards
now put the dowel thew the cams thew the holes drilled in the five inch boards
one you have the cams in the right position use wood glue to attach them and put them back between the boards
Step 4: Assembleing the Box
using the built cams mark the position compared to the 9 inch board and then drill holes on the marked position using a drill that is slightly longer then the second dowel
once the holes are drilled use a clamp and screws to attach the boards as shown above
Step 5:
using epoxy and some webbing attach the wings to the bird
cutting the second dowel in to three parts these are the push rods
next drill a small hole in the top part of the Popsicle sticks and then cut of the tops with the hole of the Popsicle sticks
then stick them on with epoxy
drill an equally sized hole in each of the push rods by the top
Step 6: Attach the Push Rods
using the wire put it thew the tips of the Popsicle sticks on the bird and then connect them thew a wire
then put the push rods the the holes drilled in the top and then it is Done
