Introduction: Engraving Vise, Mini Swivel - Using a Locking Caster
I have been wanting to make a smaller lighter engraving vise to travel with. My current engraving vise is small but it is heavy, It actually broke out the side of my tool box while moving it. So I made a mini swivel vise using a lockable caster. It allows me to easily move my workpiece in all directions. The locking part of the caster can set an angle to help.
- 1X- 3 inch caster with brake, with bearing swivel - 121 pound rated
- 1X - 2 inch diameter pin vise (4X -pegs for workpiece holding)
- 1X- 3 inch by 4 3/4 inch by 1 inch thick Wood - ( I used composite deck board) --BASE
- 1X- 3 3/4 inch by 1 inch by 1/8 inch thick Aluminum or steel -- FRAME
- 4X - bolts 5/16 inch diameter by 1/2 inch length -- SECURE CASTER TO WOOD BASE
- 1X - bolts 5/16 inch diameter by 1/2 inch length -- SECURE FRAME TO PIN VISE
- 4X - Screws 3/16 inch diameter by 3/4 inch length -- SECURE FRAME TO CASTER
Step 1: Tools
Drill (I used a cordless)
Drill bits (these will vary based on what you use for screws and bolts etc...)
- 1/4 inch -- for pilot hole into wood base
- 11/64 inch - for screws into caster
- 5/16 inch -- for hole in frame to mount pin vise
- 1/8 inch -- for pilot holes in caster
Flat file
Sand paper (180 grit but not critical on grit)
Scuff pad
micrometer
1/2 inch open end wrench
Philips screw driver
Angel (measuring)
Ruler
Small vise
hacksaw (metal cutting saw)
Transfer punch 21/64
Table saw - wood handsaw would also work
Ear protection
Hammer
Blue tape
Step 2: PIN VISE
2 inch diameter pin vise (4X -pins /pegs for workpiece holding)
Remove the top off the handle by unscrewing
Step 3: FRAME
Cut to length
Lay out and drill holes
- 11/64 inch - for screws in frame
use flat file to clean burrs
use sandpaper and scuff pad to clean surface of frame
put in vice and bend at halfway point to a 90 degree angle. Use hammer is best
Step 4: Make Base
Cut wood down to size, I am using an composite deck board.
I used my table saw but a hand saw would also work.
Make sure to wear eye and ear protection while operation of power equipment
Layout hole location to mount caster to base
I put the caster on the wood base and put 1 inch spacing from top to bottom and 3/8 spacing from left to right
I used blue tape over caster to hold in place on the wood.
I used the the transfer punch 21/64 to mark the drilling locations
remove caster from base
Drill pilot holes of 1/4 - you can thru drill the wood.
Step 5: Mount Vise to the Frame
Mount Vise To The Frame by first cutting down a bolt.
I could not find the right size (length) in my bolt collection, so I needed to cut down a longer bolt to size
To maintain a good thread at the end, I put a nut on the bolt, this also helps in holding it in the bench vise.
I leave the portion that I am going to remove hanging out of the bench vise.
Using a hack saw (metal saw) cut the bolt to 3/8 inch length
I had a clearance issue with my first hole - so I drilled a second hole
Mount the vise on top of the frame and use bolt to secure
Step 6: Mount Frame to Caster
In mounting the frame to the caster
I used blue tape to hold frame in place on the caster.
Drilled thru the frame mounting holes with a 1/8 diameter drill into the outside resin
Mount screws using the screw driver
Step 7: Mount Caster to Base
In mounting the caster to the base I use the
Tighten
Step 8: Using the Swivel Vise
I mounted a piece of copper stock
blacken with a marker - which helps see the cuts
I use hand push engravers - can not afford a power graver
Instead of pushing the hand graver- using the vise to move the work piece into the point works better for me.
OH self taught - might be better ways
The vise is very solid and the cast I used did not create and chatter (bounce in the graver)
Step 9: Thank You So Much for Viewing
I want to thank you for viewing my pin vise instructable
I have some extras below
MY tools
by bench vise simple hack
I will be creating another instructable on making pins
Step 10: My Engraving Tools
I added a photo of my engraving tool collection. I say collection because it has taken me many years to find and make the tools.
Thank you again.
Step 11: Bench Vise Simple Hack
I have to store my bench vises
I worked in a barn for 30 years which rust is created on all my metal surfaces
My vise would lock together by the jaws rusting shut.
to eliminate this I put things in between the jaws and close.
this size bench vise I used an old plastic hotel key
Just a thought
Thanks again
