Enormous Led Mood Light
Intro: Enormous Led Mood Light
The Enormous led Mood light is basically a huge 3x3x3 led cube, but in order to make it huge each led is put into a paper lantern.
Once finished this makes for a great disco light. This instructable will show you step by step how to Build the huge LED cube that will be controlled by an Arduino. I included all the code used near the end : )
STEP 1: Gather Your Tools
To start of you will need these tools...
.hot glue gun
.soldering iron
. Wire Strippers
.scissors
. ruler
Optional ladder
.hot glue gun
.soldering iron
. Wire Strippers
.scissors
. ruler
Optional ladder
STEP 2: Gather Your Materials
To start of you will need these materials:
. stranded wire about 24 feet
. solid core wire 5 feet
. fishing string
. paper lanterns(27)
. Arduino uno
. pcb
. 12 Resistors (~220 ohms)
. cat 5 cable
. electrical tape
. 3 NPN Transistors (2N2222, 2N3904, BC547, etc.)
. 27 LEDs Color is optional i used these:http://www.radioshack.com/product/index.jsp?productId=2062588
. Optional- breadbord
. fishing string
. Arduino uno
. pcb
. cat 5 cable
. electrical tape
STEP 3: Make the Led Lanterns
To make the 27 led lanterns first :test leds first .Then snip two wires 3in long twist the wires with the led leads and tape with electrical tape or solder them.
test the leds again
now cut a solid core wire 4 in. and wrap it around the electrical insulation of the led you just made and hot glue it in place.
take he paper lenterns and open them up. Next rest the solid core wire on the the lantern and hot glue it in place.
now make 26 more! don't forget to label the negative wire
test the leds again
STEP 4: Constructing the Cube
now its time to construct the mood light .
First cut 9 strings five feet in length then with a ruler draw a squarer that is 16 in by 16 in
mark at the 0,8,and16 inches . then draw a line from the 8 in mark to the other 8 in mark . do this for both sides and you should end up with a cross . now tape or hot glue the 5 feet long strings on the 0,8,16 in marks including the center . now you can begin the first layer .
Tie the first layer of nine lanterns then measure 5in and cut the fishing wire then pass the fishing wire
through the tiny hole underneath the next lantern and tie a knot to keep the lantern beneath from falling do this for all of the next layer now for the last layer do the same and tie the rows of 3 lanterns to the remaining wire hanging from the ceiling .
STEP 5: Time for the Wiring
For the wiring cut 27 five inch long stranded wires to connect all of the cathodes or negative side of an led together in one layer
then cut 16 six inch long wires to connect all the positives in the nine columns of three.
STEP 6: Building the Circuit
the Circuit is very basic. Each of the nine columns will connect to a pin on the Arduino through a current limiting resistor (220 OHMS).
Each of the three levels connects to ground via a NPN transistor when activated by an Arduino pin . following the schematic solder 9 resistors to the pcb leaving as much room as possible then solder the 3 NPN transistors and there corresponding resistors to the pcb.
STEP 7: Wiring the Arduino
now number the resistors 1,2,3,4,5,6,7,8,9, and the transistor Circuit L1,L2,L3 then number the lanterns(1,2,3,4,5,6,7,8,9) and with the
cat 5 cable connect the resistors to its corresponding columns by number like resistor 1 to column 1.
Connect resistor No. 1 to pin 2 on the arduino.
connect resistor 2 to pin 3 and so for until you get to resistor 9 connected to pin 10.
L1 connects to pin 11; L2 connects to pin 12 and L3 connects to pin 13.
STEP 8: Software
Please rate this instructable if you like it! :) here is the code that i used so that you can copy and paste it:
#define DRAW_PWM_DELAY 10
#define MAX_INTENSITY 8
* LED Driver
byte columnPins[] = {2,3,4,6,7,8,11,12,13}; // connections of matrix colums
byte levelPins[] = {5,9,10}; // connections of matrix levels
// initializes the LED driver (sets pin modes and turns all LEDs off)
void ledInit() {
for (byte i=0; i<9; i++) {
pinMode(columnPins[i], OUTPUT);
digitalWrite(columnPins[i], LOW);
for (byte i=0; i<3; i++) {
pinMode(levelPins[i], OUTPUT);
digitalWrite(levelPins[i], HIGH);
// switch on single LEDs
// causes other LEDs to light up if driver is not in initialized state
// (you can not address all the 27 LEDs with just 12 pins at a time)
void ledOn(byte column, byte level) {
digitalWrite( columnPins[column], HIGH );
digitalWrite( levelPins[level], LOW );
// same like ledOn
void ledOff(byte column, byte level) {
digitalWrite( columnPins[column], LOW );
digitalWrite( levelPins[level], HIGH );
* Basic Drawing API (voxel buffer, cartesian coordinate system, etc.)
byte buffer[27]; // voxel buffer
// draws the voxel buffer (ignoring intensities)
// any voxel >1 will turn on the corresponding LED
void draw(byte n) {
int col,lvl;
for (byte t=1; t<n; t++) {
for (byte i=0; i<27; i++) {
if (buffer[i]) {
col = i/3;
lvl = i%3;
ledOn(col,lvl);
delayMicroseconds(DRAW_PWM_DELAY);
ledOff(col,lvl);
} else {
void draw() {
draw(1);
// draws the voxel buffer (takes intensities into account)
// this functions uses a software PWM and is about 128 times slower
// than the binary draw function
void drawPwm() {
int col,lvl;
for (byte t=1; t<=128; t++) {
if (!(t % (1<<(8-buffer[i])))) {
col = i/3;
lvl = i%3;
ledOn(col,lvl);
ledOff(col,lvl);
} else {
// clears voxel buffer
void clearBuffer() {
buffer[i] = 0;
// fills voxel buffer
void fillBuffer(byte value) {
buffer[i] = value;
// retrieves values from voxel buffer (using cartesian coordinates)
byte getVoxel(char x, char y, char z) {
byte i = 9*x - y + 3*z + 13;
return buffer[i];
// sets values from voxel buffer (using cartesian coordinates)
void setVoxel(char x, char y, char z, byte value) {
if (i>=0 && i <= 27) {
buffer[i] = value;
// interpolates arbitrary points between voxels
void setPoint(float x, float y, float z, byte value) {
char xint = x>0 ? 1 : -1;
char yint = y>0 ? 1 : -1;
char zint = z>0 ? 1 : -1;
interpolate(x,y,z,value,0,0,0);
interpolate(x,y,z,value,0,yint,0);
interpolate(x,y,z,value,0,0,zint);
interpolate(x,y,z,value,0,yint,zint);
interpolate(x,y,z,value,xint,0,0);
interpolate(x,y,z,value,xint,yint,0);
interpolate(x,y,z,value,xint,0,zint);
interpolate(x,y,z,value,xint,yint,zint);
void interpolate(float x, float y, float z, byte value, char xint, char yint, char zint) {
float d = sqrt(pow(xint-x,2) + pow(yint-y,2) + pow(zint-z,2));
byte i = 9*xint - yint + 3*zint + 13;
buffer[i] += (value * (1-d));
* Some Demos
// sets pin states manually (driver not used)
void demoLowLevel() {
ledInit();
// nothing visible happens here
for (byte lvl=0; lvl<3; lvl++) {
digitalWrite( levelPins[lvl], LOW );
// now we select entire colums
for (byte cycle=0; cycle<2; cycle++) {
for (byte col=0; col<9; col++) {
digitalWrite( columnPins[col], cycle % 2 == 0 ? HIGH : LOW );
delay(100);
ledInit();
digitalWrite( columnPins[col], HIGH );
// now we select entire levels
digitalWrite( levelPins[lvl], cycle % 2 == 0 ? LOW : HIGH );
delay(200);
ledInit();
// some rotations (no driver used as well)
void demoRotation() {
// rotation sequence
byte seq[] = {0,1,2,5,8,7,6,3};
ledInit();
// active all levels
// middle column
digitalWrite( columnPins[4], HIGH);
int cycles = 3*3*9;
for (int cycle=0; cycle<cycles; cycle++) {
digitalWrite( columnPins[seq[cycle%8]], HIGH);
digitalWrite( columnPins[seq[(cycle-1)%8]], LOW);
if (cycle >= 3*9) {
digitalWrite( columnPins[seq[(cycle+4)%8]], HIGH);
digitalWrite( columnPins[seq[(cycle+3)%8]], LOW);
if (cycle >= 2*3*9) {
digitalWrite( columnPins[seq[(cycle+2)%8]], HIGH);
digitalWrite( columnPins[seq[(cycle+1)%8]], LOW);
digitalWrite( columnPins[seq[(cycle+6)%8]], HIGH);
digitalWrite( columnPins[seq[(cycle+5)%8]], LOW);
delay(100);
ledInit();
// direct access to voxel buffer (cartesian coordinates not used)
void demoFill() {
clearBuffer();
for (int cycle=0; cycle<2; cycle++) {
for (int i=0; i<27; i++) {
if (cycle % 2 == 0) {
buffer[i] = 8;
} else {
buffer[i] = 0;
draw(50);
// treats voxels as bins and fill them bit by bit randomly
void demoBinFill() {
clearBuffer();
for (int i=0; i<100; i++) {
buffer[random(0,28)]+=2;
drawPwm();
// neat random sparkle
void demoSparkle() {
for (int density = 0; density<50; density++) {
for (int cycle = 0; cycle < 3; cycle++) {
clearBuffer();
for (int i=0; i<density; i++) {
buffer[random(0,28)] = random(0,9);
drawPwm();
// makes all LEDs pulse synchronously
void demoPulse() {
for (int cycle=0; cycle<80; cycle++) {
fillBuffer(-abs(cycle%16-8)+8);
drawPwm();
// pulsing wave
void demoPulseWave() {
byte r;
for (byte cycle=0; cycle<80; cycle++) {
for (char x=-1; x<=1; x++) {
for (char y=-1; y<=1; y++) {
for (char z=-1; z<=1; z++) {
r = (x*x + y*y + z*z);
setVoxel(x, y, z, -abs((cycle-r)%16-8)+8);
drawPwm();
// demonstrates interpolation
void demoGlowfly() {
float dx,dy,dz;
byte steps = 10;
float px = random(-100,101)/100.0;
float py = random(-100,101)/100.0;
float pz = random(-100,101)/100.0;
for(int cycle=0; cycle<8; cycle++) {
dx = (random(-100,101)/100.0 - px) / steps;
dy = (random(-100,101)/100.0 - py) / steps;
dz = (random(-100,101)/100.0 - pz) / steps;
for (int i=0; i<steps; i++) {
px += dx;
py += dy;
pz += dz;
clearBuffer();
setPoint(px, py, pz, MAX_INTENSITY);
drawPwm();
* LED Driver
void ledInit() {
// same like ledOn
void draw(byte n) {
int col,lvl;
if (buffer[i]) {
col = i/3;
lvl = i%3;
ledOn(col,lvl);
ledOff(col,lvl);
} else {
void draw() {
draw(1);
void drawPwm() {
int col,lvl;
col = i/3;
lvl = i%3;
ledOn(col,lvl);
ledOff(col,lvl);
} else {
buffer[i] = 0;
buffer[i] = value;
return buffer[i];
buffer[i] = value;
* Some Demos
ledInit();
delay(100);
ledInit();
delay(200);
ledInit();
ledInit();
// middle column
int cycles = 3*3*9;
if (cycle >= 3*9) {
delay(100);
ledInit();
void demoFill() {
clearBuffer();
buffer[i] = 8;
} else {
buffer[i] = 0;
draw(50);
clearBuffer();
drawPwm();
clearBuffer();
drawPwm();
void demoPulse() {
drawPwm();
// pulsing wave
byte r;
drawPwm();
float dx,dy,dz;
byte steps = 10;
px += dx;
py += dy;
pz += dz;
clearBuffer();
drawPwm();
3 Comments
maroelawerner 12 years ago
akwan1 12 years ago
Robo-labs 12 years ago
