Introduction: Epoxy Pendant With a Druzy Quartz Look
This instructable will show you how easy it is to use mini crystal rhinestones to make a pretty pendant!☆
• mini aurora borealis rhinestones 1.2mm size ( approximately 1/4 teaspoon; which is a little more than you need).
• 1 silicon pendant mold ( any shape you choose).
• 1 gemstone or broken pieces of gemstones ( any size that is smaller than the inside your silicon mold).
• 2 part epoxy ( I used Gorilla glue epoxy).
• 1 toothpick ( to mix the epoxy).
• 1 small disposable container ( to mix the epoxy).
Step 1: Mix Epoxy
With the toothpick, mix your epoxy thoroughly for approximately 30 seconds inside a disposable container.
Step 2: Epoxy Into the Mold
Pour the epoxy into the pendant mold; a little more than half of the way full ( leaving a space for the mini rhinestones, so the epoxy doesn't over flow out of the mold).
Place the mini aurora borealis rhinestones into pendant mold into the epoxy; before the epoxy dries. With your finger lightly tsp on top of the rhinestones. Let the epoxy dry for 30 minutes before moving on to step 4.
Step 3: Remove From Mold
After at least 30 minutes, remove the dried epoxy from the mold ( There will be loose rhinestones on top of your pendant that will fall off, that's okay ). Your pendant is finished! Add a jewelry loop and attach the pendant to a chain or chord necklace. Wear or gift your creations! ☆
☆ Please share photos of your creations! ☆
