Introduction: Epoxy Resin Fantasy Garden
About: Hi everyone! When I met this website I didn't doubt to register to start sharing, commenting, learning and participating. I hope you like my publications! You guys are great!
Today I show you how I make these beautiful fantasy gardens, in epoxy resin. You can use it as a pendant, earrings or whatever you can think of, you can change the shape and make it into circles, triangles, etc. Let your imagination fly and create these landscapes.
Hoy os enseño cómo hago estos jardines de fantasía tan bonitos, en resina epoxi. Puedes usarlo como colgante, pendientes o lo que se te ocurra, puedes cambiar la forma y hacerlo en círculos, triángulos, etc. Deja volar tu imaginación y crea estos paisajes.
  • Epoxy resin
  • Pigments for resin
  • Molds
  • Flowers
  • Bubbles
  • Hooks for earings
  • Pliers
  • Resina epoxi
  • Pigmentos para resina
  • Moldes
  • Flores
  • Burbujas
  • Ganchos para pendientes
  • Alicates
Step 1:
Warning: you must protect yourself, wear a mask and gloves when working with the resin.
Aviso: tienes que protegerte, ponerte máscara y guantes para trabajar con al resina.
Step 2: Select the Flowers
These are antique flowers, made from bread crumbs, but the flowers can be purchased, handmade with clay or natural, well dried.
Estas son unas flores antiguas, hechas de miga de pan, pero las flores pueden ser compradas, hechas a mano con arcilla o naturales, bien secas.
Step 3: Mix Two Components
Prepare the resin mixture. My resin mixes in proportions of 100:60, so I made an amount of 50 of component A and 30 of component B (although to do this we will need less). Stir slowly in all directions, going through the stools until the mixture is homogeneous. Let stand for about 5 minutes so that the bubbles disappear.
Preparar la mezcla de resina. Mi resina se mezcla en proporciones de 100:60, por lo que hice una cantidad de 50 de componente A y 30 de componente B (aunque para hacer esto necesitaremos menos). Remover despacio en todas las direcciones, pasando por las pareces hasta que la mezcla quede homogénea. Dejar reposar unos 5 minutos para que desaparezcan las burbujas.
Step 4: Start
Pour resin without filling the mold completely, put in the flowers and green leaves, create your design. Fill the mold almost to the top.
Echa resina sin llenar del todo el molde, mete las flores y las hojas verdes, crea tu diseño. Llena el molde casi hasta arriba.
Step 5: Details
In another glass, mix some resin with green resin pigment. Put some on the bottom of the mold and stir it to create the grass.
En otro vaso, mezcla un poco de resina con pigmento para resina verde. Pon un poco en la parte de abajo del molde y remuévelo para crear el césped.
Step 6: Details
Do the same with the blue, I used mica powder to give it a shiny touch. And put very little white for the clouds. I also put bubbles for decoration.
Haz lo mismo con el azul, yo usé polvo de mica para darle un toque brillante. Y pon muy poco blanco para las nubes. También le puse burbujas para decorar.
Step 7: Earings
Take it out of the mold, put some earring hooks on it and that's it.
Saca del molde, ponle unos ganchos de pendientes y listo.
