Introduction: Eraser Stamp
We are going to make an Eraser Stamp
Using the instruction Make your original and unique stamp!!
Step 1: Material
- Hobby knife
- Eraser block
- Tracing Paper/Paper
- Ink
- Pencil
- Ruler
For eraser size, shape, type of Eraser doesn't matter, but I would suggest using the eraser for the stamp.
But can be done with the normal eraser, for the school or so.
Step 2: Design
Draw the design on paper.
- Draw the shape of the eraser with an exact size
- Draw your design inside of the shape
Step 3: Cutting
Put a knife to the design, and cut the part where you want to cut.
**BE CAREFUL WHEN YOU USE KNIFE**
4 skills to cut
Place pressed carving
- Put the eraser on the table
- Hold the blade across from you
- Put the blade into the eraser and turn the eraser to cut
Place Pull carving
- Hold the blade towards you
Holding Pull carving
- Hold the eraser
Holding pressed carving
- Hold the eraser
Step 4: Finish!
Check how it looks like using ink
Adjust if it is not the form you want
