Introduction: Eraser Ball (3DP) by Samuel Bernier
I love the shape of these vintage erasers. When I saw a whole bag of them for only 99 cents at Office Depot, I had this idea for a little office toy. 3D printing fanatics, here is my gift to you.
123D link : http://www.123dapp.com/AssetManager/Publisher?stgAction=getProduct&intProductId=597788
T
hingiverse link : http://www.thingiverse.com/thing:17992
Step 1: STL Model
You will first need to download this .STL file, and send it to print.
Step 2: Find a 3D Printer
I used an UP! 3D printer and it worked very well. It took me a while to optimise it, but I'll post that in an other Instructable.
Step 3: 3D Print
I used White ABS with normal definition. I suppose that PLA would also work fine.
Step 4: Clean
If you used a RepRap 3D printer, you will need to remove the support plastic with tweezers or needle-noze pliers.You might also want to use sandpaper to remove the rough texture.
Step 5: What You Need
Once you have the core, get 14 eraser tips. They come in many colors, so you have the choice!
Step 6: Shine
If you want to be fancy and have a shiny surface, you can use a little bit of acetone. Be careful because it actually melts the plastic so use a brush (real hair because synthetic ones will also melt). If you put to much acetone on the little harms, they will shrink and the tolerances will change.
Step 7: Insert
Insert the erasers!
Step 8: Touch Up
If you DID abuse on acetone, you will need to put a little bit of glue for the assembly.
Step 9: Erase
SURPRISE! The eraser-ball erases!
Step 10: Play
It also easily becomes a distracting office game.
Have fun!
-Sam
