Introduction: Ereader Is Optional by Using Your Portable Music Player and MSWindows
Why get an ereader when you can use an inexpensive music player to listen to your files and keep your eyes rested. It is also safer to carry a portable music player than a bulky ereader. The program you use may be different, so that is why I did not include deeper explanation. Should all be point and click.
Note: I am not condoning any particular music player. you should decide that for your self. This instructable may require the use of an internet search engine. It is also beyond the scope of this instructable on how to do that. Beginning computer users may want to get help with how to find and install software on an MSWindows computer.
Step 1: Get the Pdf to Text Software.
Find, download, and install PDF Ripper. Use this software at your own risk. There are several programs to do this, but this is the first one I found.
Step 2: Get the Text to Wav Software.
Find, download, and install textto speech. . Use this software at your own risk. There are several programs to do this, but this is the first one I found.
Step 3: Convert Pdf to Text.
Follow the directions to convert pdf (most ereader files are in .pdf format) to text (not html) and save the file where it is easy to find.
Other programs can be found with: http://tinyurl.com/263yz9s
Step 4: Now You Want to Take Text to a Wav File.
Follow the directions to convert text to wav and save the file where it is easy to find.
Note another way: http://support.microsoft.com/kb/306902
How to configure and use Text-to-Speech in Windows XP and in Windows Vista
TTS is the ability of the operating system to play back printed text as spoken words. An internal driver, called a TTS engine, recognizes the text and using a synthesized voice chosen from several pre-generated voices, speaks the written text. A TTS engine is installed with the operating system. Additional engines are also available through third-party manufacturers. These engines often use a certain jargon or vocabulary; for example, a vocabulary specializing in medical or legal terminology. They can also use different voices allowing for regional accents such as British English, or speak a different language altogether such as German, French, or Russian.
The Text-to-Speech tab in the Speech tool in Control Panel presents the options for each TTS engine. See the individual Help topics for specific help. In addition to the general options, each engine can have a different set of specific features. For that reason, not all the resulting dialog boxes will look the same. It is possible that no special features have been included and some of the properties buttons will not have an associated dialog box.
Setting Up Your HardwareNOTE : This article assumes that you use Classic View in Control Panel. To change views, follow these steps:
To set up speakers, follow these steps:
To set up audio output device options, follow these steps:
Change the TTS Voice or Engine To change the Text-to-Speech voice or engine, follow these steps:
Narrator is designed to work with the Notepad, WordPad, Control Panel programs, Microsoft Internet Explorer, the Windows desktop, and Windows Setup. Narrator may not read words aloud correctly in other programs.
Narrator has a number of options that allow you to customize the way screen elements are read.
Narrator is not available for all languages and is only supported on the English version of Windows XP and Windows Vista.
To Have Narrator Announce Events on the Screen
This article was previously published under Q306902
To continue receiving security updates for Windows, make sure you're running Windows XP with Service Pack 3 (SP3). For more information, refer to this Microsoft web page: Support is ending for some versions of Windows (http://windows.microsoft.com/en-us/windows/help/end-support-windows-xp-sp2-windows-vista-without-service-packs)
On This PageSUMMARY
Text-to-Speech (TTS) capabilities for a computer refers to the ability to play...
Text-to-Speech (TTS) capabilities for a computer refers to the ability to play back text in a spoken voice. This article describes how to configure and use text-to-speech in Windows XP and in Windows Vista.TTS is the ability of the operating system to play back printed text as spoken words. An internal driver, called a TTS engine, recognizes the text and using a synthesized voice chosen from several pre-generated voices, speaks the written text. A TTS engine is installed with the operating system. Additional engines are also available through third-party manufacturers. These engines often use a certain jargon or vocabulary; for example, a vocabulary specializing in medical or legal terminology. They can also use different voices allowing for regional accents such as British English, or speak a different language altogether such as German, French, or Russian.
- Click Start, and then click Control Panel.
- In Control Panel, click Switch to Classic View or Switch to Category View.
Locate the sound connections and connect the speaker jack to the computer. Most computers use an internal sound card and often the connections are in the back of the computer. These are a series of connections the same size and diameter as the speaker jack. In many cases there are two sound out connections:
- One will be labeled as a line-out connection. Most speakers that require a separate power supply (such as an electrical (AC) adapter or batteries) should use this connection. It is also used to export amplified sound to recording devices including recordable CDs and tape cassette systems.
- The other connection is for the non-powered speakers. Because the signal is boosted by the computer, powered speakers may be damaged if connected.
- Plug the speaker into the proper connection.
To test the connection, follow these steps:
- Click Start, click Control Panel, and then double-click Speech.
- On the Text-to-Speech tab, click Preview Voice to hear the currently selected voice. The text is spoken and the words are highlighted as they are spoken. If the speakers are working properly, you will hear the spoken words.
- On the Text-to-Speech tab, click Audio Output.
Select either Use preferred audio output device or Use this audio output device.
- Use preferred audio device sets the output device as the default for the system. Select this option if you want to use the same output device for speech as all other sound for the system. It is also the default option for Speech properties. Often, computers will have only one output device, such as a pair of speakers. The default device is designated in the appropriate sounds or multimedia properties in Control Panel for each operating system. Additional information for the specific panel is available through the associated Help files.
- Use this audio output device allows you to select another device for speech programs only. The drop-down list is active if other devices are available. In this drop-down list, select the device that you want. This does not change the default device for other audio programs. For example, you may want all speech output to go through your headset rather than the speakers.
- Follow the instructions presented on the screen.
On the Text-to-Speech tab, the displayed name in the Voice selection drop-down list is the currently active voice. - Click Preview Voice to hear the active voice. The text is spoken and the words are highlighted as they are spoken.
On the Text-to-Speech tab, the displayed name in the Voice selection drop-down list is the active voice. - Click Preview Voice to hear the currently selected voice. The text is spoken and the words are highlighted as they are spoken.
- During playback, Preview Voice will change to Stop. Click Stop to interrupt the voice playback.
- On the Text-to-Speech tab, the name displayed in the Voice selection drop-down list is the active voice.
- Click the active voice inside the drop-down list, or use the arrow to display a list of available voices.
Click a new voice to select it.
The newly selected voice speaks the text in Preview Voice box. - Click OK or Apply to accept the new voice.
- A Text-to-Speech voice is closely associated with a particular speech engine. It may not be clear from the displayed name which language a voice is using. After selecting a speech engine or voice, test the voice and language by clicking Preview Voice.
- The language or voices supported by a speech engine may not be obvious from the engine's displayed name. Refer to the specific user's guide for detailed information about the engine. This includes not only the language supported, but also the lexicon purpose. The lexicon purpose indicates whether it is a general grammar or jargon specific to a profession such as legal or medical.
Microsoft does not provide additional speech engines (voices), but a number of third-party products are available that support the new Microsoft Speech API. For information on these products, visit the following Microsoft Web site:
http://www.microsoft.com/speech/evaluation/thirdparty/engines.mspx (http://www.microsoft.com/speech/evaluation/thirdparty/engines.mspx)
- Select the Text-to-Speech tab.
- Move the Voice speed slider to change the rate of the Text-to-Speech voice. By default, it is set to Normal.
- Click Preview Voice to hear the currently selected voice at the new rate. The text is spoken and the words are highlighted as they are spoken.
- On the Text-to-Speech tab, click Audio Output, and then click Volume.
- A volume control mixer will be displayed. Adjust the appropriate device to the required level.
- You can have new windows, menus, or shortcut menus read aloud when they are displayed.
- You can have typed characters read aloud.
- You can have the mouse pointer follow the active item on the screen.
- You can adjust the speed, volume, or pitch of the voice.
Start Narrator by using one of the following methods:
Click Start, point to Programs, point to Accessories, point to Accessibility, and then click Narrator.
-or- - Press CTRL+ESC, press R, type narrator, and then press ENTER.
- In the Narrator dialog box, select the Announce events on screen check box.
- Select the Read typed characters check box.
- Select the Move mouse pointer to the active item check box.
- To read an entire window, click the window and then press CTRL+SHIFT+SPACEBAR.
- To get information about the current item, press CTRL+SHIFT+ENTER.
- To get a more detailed description of an item, press CTRL+SHIFT+INSERT.
- To read the title bar of a window, press ALT+HOME.
- To read the status bar of a window, press ALT+END.
- To read the contents of an edit field, press CTRL+SHIFT+ENTER, or use the arrow keys.
- To silence the speech, press CTRL.
- To switch to another program, press ALT+TAB.
- To switch to the next button or tool, press TAB. To go back, press SHIFT+TAB.
- To select an item from a drop-down list, use the arrow keys.
- To select a check box or option button, press SPACEBAR.
- To open Utility Manager, press the Windows logo key+U.
- Press CTRL+ESC, press R, type narrator, and then press ENTER. Click Voice.
In the Voice Settings dialog box, select the voice options that you want to change:
- To change the speed of the voice, click a number in the Speed box.
- To change the volume of the voice, click a number in the Volume box.
- To change the pitch of the voice, click a number in the Pitch box.
- Select the Start Narrator minimized check box.
- On the Text-to-Speech tab, click Preview Voice. The text in Preview Voice should be spoken audibly with each word highlighted in turn. If so, TTS and the speakers are working. If you cannot hear the Preview Voice and see words highlighted as they are spoken, see "Possible Text-to-Speech Problems" section of this article for troubleshooting solutions.
- The speaker volume is not turned up or is muted. Some speakers have external controls for volume and muting. Make sure the volume is turned up sufficiently or that muting is off.
- The speakers may not be selected as the current output device. On the Text-to-Speech tab, click Audio Output to make sure that the speakers are selected.
- The speakers might not be connected properly. Consult the speaker hardware documentation for additional information. Make certain that the sound card for the computer is also properly seated and installed, and that the correct drivers are available. See "Set Up Speakers" for additional connection information.
- The Text-to-Speech engine may be corrupted. To test for corruption, switch to another engine. See the "Changing the TTS voice or engine" section of this article. If another engine is working properly, reinstall the specific engine from the original source. If no engine is working properly, reinstall the speech engine from the original source or CD.
Step 5: To the Media Player.
Now copy the wav file to your media player.
