Introduction: Make an Eskimo Style Kayak Paddle From 2x4 Scrap Wood in 1.5 Hours
This traditional pattern of paddle is a joy to use. The blades aren't feathered (rotated relative to each other) so they're easy for beginners to use.
I just made two of these in less than 3 hours according to the timestamps on the photos.
I wasn't rushing, that's just how long it took.
Read Nativewater's Eskimo paddle pages to learn theory and refinements of this type of paddle.
Paddle Dimensions:
The paddle is 7 to 8 feet overall.
The blades are 3.5" wide at the tips and 2.5" wide where they meet the handle.
The handle portion in the middle is 24-27" long, 1.2" wide, and 1.5" thick.
Size the handle portion to suit yourself.
Tools I used:
safety glasses
dust mask (very important. You'll be making storm clouds of dust)
table saw or bandsaw or jig saw or hand saw for cutting the outline
hand saw (Japanese pull saw)
electric planer
angle grinder
with Porter Cable 24 grit carbide disk ($7!)
with 50 and 80 grit resin bond sanding disks
sandpaper
C clamp
ruler and magic marker
More paddle and oar making projects:
Here's the quickest way I know to make a paddle.
If it's oars you need, here's how to make oars from 2x4s.
Make a steering oar for a Marshall Islands Racing canoe.
Paddle Dimensions:
Tools I used:
safety glasses
electric planer
angle grinder
sandpaper
C clamp
Step 1: Get Wood
I brought a paddle with me to help see where any knots would be if I used a certain chunk of lumber to make a paddle.
Dig around in the guts of a demolished house or barn til you find a softwood 2x4 about 8 feet long Look for straight grain and no knots where the middle handle portion.
Knots in the blade area are okay, imagine whether the knots will make the paddle too weak or not.
Usually it's easier to find clear wood on a bigger plank such as a 2x6, 2x12, etc. They came from a bigger tree and you've got more leeway to dodge knots.
New cheap 2x4s tend to be the core slice from a log and have lots of knots from the baby tree.
I found a good old 2x8 with knots in all the places that wouldn't be paddles. It's weathered and severely cracked, but that doesn't bother me. The blades are carved down past the bottom of the cracks. I'll fill any cracks in the handle portion.
Step 2: Make 2x4s : )
I saw the plank lengthwise on my little bandsaw. I use the bandsaw instead of the table saw because the blade is very thin and wastes no wood.
I got this band saw for free because it looks ugly to the world, although it is beautiful to me and has many fine features.
Step 3: Lay Out the Paddle
Draw the paddle on the plank with a magic marker.
The paddle is 8 feet overall. The handle portion in the middle is 27" long and 1.2" wide.
The tips are round. Trace the lid from a yogurt tub.
Step 4: Danger! Freehand Tablesaw Cutting
Usually people use a bandsaw or jigsaw to cut the outline. That's a better method. A handsaw, stone adze, etc is fine also.
I freehand cut the outline on my table saw. It's fast and dangerous to do that way.
Wood chips get flung at your face.
Wear safety glasses, keep the whole area clear, and have no distractions.
Make multiple cuts into the handle area so the blade doesn't bind.
I got this table saw for free because there are too many table saws in the world. Also this one had many pieces broken off it. Maybe it really fell off a truck. But the table is flat, the blade is square, and the parts I need still work. The only part I needed to order was the nut that holds the blade on.
Step 5: Trim With Hand Saw and Mark the Edges
Use a hand saw to trim the stuff you can't get to with the table saw.
Mark the centerline on the sides of the blades.
Mark the sides of the blades with a straight taper that goes down to 1/2" thick at the tip
Step 6: Electric Planer
Clamp the paddle securely.
Plane down the blades with an electric planer. Plane them flat and taper them down to 1/2" thick at the tips.
Then plane the blades down to a 1/8" edge all around the edge.
Flex the paddle and heft it. Keep shaving it down until it's light but not too flexible.
Trust your intuition about this.
Step 7: 24 Grit Carbide Disc
Porter Cable makes a really great carbide chip abrasive disk for $7. Really great for carving wood.
Dangerous! Great for carving human flesh also, so be careful.
It also flings crap in all directions and will fill your lungs with dust. War all your safety gear.
They tell you to only use it with their backing plate, but it seems to work fine with a regular stiff backing pad from a disk sander.
Wear safety glasses and dust mask. Clamp and shape the blades. Smooth out all the marks from the planer. Round the corners of the handle. I like to leave my handles mostly rectangular like a hockey stick.
Switch to a finer grit sanding disk and smooth out the gouges from the carbide chip wheel.
Hand sand with finer grits of sandpaper until you're satisfied with the finish. Use epoxy mixed with wood dust to fill any cracks or glue back any chips that broke off during shaping. Finish the paddle with linseed oil, varnish, or whatever you prefer. Some people leave the part your hands will grip unfinished.
I like linseed oil because I can soak it in, wipe it dry, and
Go paddling!
Go paddling!
