Introduction: Etching PCB With HCL and Hydrogen Peroxide
This is a DIY method of making PCB using HCL and hydrogen peroxide .
Detailed instructions can be found also in https://xkobyx.blogspot.com
Visit my Youtube channnels : Electro_Magic ; Practical Tips ; Delphi practical school
The most important thing is to have good print , done with good quality toner.
Here we use some dangerous chemicals so be very careful if you going to do this at home.
Please check following video for details, and I will show you also few steps in following points.
- HCL
- Hydrogen peroxide
- Plastic box
- Steel Wool
Step 1: Prepare Copper Clad With Print
First you must have good print, done with good quality toner, or done by any other technique .
Then we put prepared PCB in plastic box.
Step 2: Add HCL and Hydrogen Peroxide
For etching we use HCL and Hydrogen peroxide.
BE VERY CAREFUL, THESE ARE HARMFUL.
We pour in HCL just enough to cover PCB, then we add a little of peroxide.
Since HCL and peroxide comes in different concentration, it is difficult to define right amount to use.
If you add too much of peroxide it will react to fast, and can go under the print and etch copper traces, so be careful, test and see what is proper amount.
Step 3: Reaction
We immediately see how reactions with copper occur.
We can see bubbles in the reaction of acid with copper, and after few minutes full reaction can be seen.
Step 4: Rinse Pcb With Water
After etching is done, we rinse pcb with water.
Step 5: Remove Any Toner Residue ( If PCB Done With Toner Method )
Use a steel sponge to remove any toner residue.
Step 6: Result
The PCB looks almost perfect.
