Introduction: Every Day Carry Leather Organizer (EDC)
LEVEL UP your EDC game with these leather organizer in the EDC scene/world. This EDC leather organizer is optimal for A5 (14,8 cm x 21 cm) notebooks with the maximum number of pages 64 (MOLESKINE, Field Notes, etc.). In addition, this organizer has two front pockets. One of the pockets is for credit cards or business cards. The other pocket can be used in my modified version for other purposes (Example: Carrying an emergency bullet :D). Originally this pocket is for a pen. By the way, leather is very robust and sustainable material. I LOVE working with leather so much. Okay, let us make one :)
Step 1: Materials and Tools
Material:
- Leather of your choice 3 - 4 oz (1.2 - 1.6 mm is my recommendation).
- Medium soft leather is better for the shape.
Tools:
- Cutter
- Ruler
- Hammer
- Half round punches
- Scratch awl
- Wood slicker
- Chisel (5 mm)
- Leather glue
- Wing divider
- 2x needles
- Sew thread
- Tokonole leather finish
- Leather balm (Protect leather and gives the leather a fresh look)
- Rotary tool (for example: Dremel) or sandpaper
- Edge beveler
- Lighter
- Crepe tape
- Coin
Step 2: Print, Cut and Tracing Out the Pattern
Download free attached pattern, print and cut them out. Transfer the pattern on each leather piece. Use the scratch awl tool. Use the ruler and cutter to cut the leather pieces out. For inner round edge use half round punches. Use thick paper if you want to make more than one.
NOTE: In this version i use crepe tape, that is why i am not exactly cutting all pattern out. In addition, i would like to make the second pockets a little different. That is why it is so cool to have a pattern. You can modify them how you want.
Use the following printer setting:
Paper size European: DIN A4
Paper size USA: US Letter
Step 3: Working on Piece No. 2 (Cutting an Inner Round Edge)
- You should have three pieces (No. 1, no. 2 and no. 3) now. The piece no. 2 have an inner round edge. Use half round punches or cut out the inner round edge by hand.
- The inner round edge have now sharp edges. Continue if you like it or you can smooth them. Use a round object, for example a sewing thread spool or a coin.
Step 4: Working on Piece No. 2 and No. 1 (Sanding and Burnishing the Upper Edges)
- For smooth edges use sandpaper or rotary tool (for example: Dremel).
- Burnish the upper edges. Use tokonole leather finish and the wood slicker to burnishing the edges. You can use water as well. You can find HERE a very useful tutorial from "Corter Leather".
NOTE: Repeat sanding and burnishing one more time for a better results. Use different types of sandpaper (First round: 400, second round: 1200).
Step 5: Working on Piece No. 2 and No. 1 (Glue Them Together, Punching Holes and Sewing)
- At the gluing points of the piece no. 2 make the leather a little rough with your cutter.
- Glue the pieces no. 1 with no. 2 together.
- Use your wing divider on the pattern no. 1 to measure the position of the seam and transfer it on piece no. 1.
- Punch holes just on the middle stiching mark and until the end of the marking!
- Sew both pieces together. For sewing i use the saddle stitch technique WITHOUT a stitching pony. HERE you can learn from "Corter Leather" how to do that.
Tipp: To remove the excess glue use a plastic card or metal ruler.
Step 6: Glue the Piece No. 3 With No. 1/no. 2 Together and Sanding the Edges
- Glue the piece no. 3 with no. 1/no. 2 together.
- For the round bottom corners use a coin. Trim the edges.
- Use a rotary tool (for example: Dremel) to smooth the thicker edges.
Step 7: Punching Holes, Sewing and Bevel the Edges
- Adjust 3 mm on the wing divider and mark the stiching lines (You are new on leather craft? Just search on YouTube for "How to use wing divider").
- Punch the holes and sew the rest together.
- For the round top corners use a coin. Trim the edges.
- Sanding all the edges. Use the edge beveler for taking off the sharp edges.
Step 8: Optional: Attach Your Logo/brand
You can use laser or punching/stamping letters too. I am using a branding stamp.
Step 9: Finishing the Edges
- Burnish the edges (see step 4).
Apply some leather balm on the smooth surface of your finished piece.
Step 10: The Finished Product
We are done! You made it! I would be glad to see your EDC leather organizer :)
*** My Links ***
Instagram: https://www.instagram.com/paracord.wolf/
First Prize in the
Leather Challenge
25 Comments
2 years ago
Both the end result and pictures look fantastic! Nice job.
Reply 2 years ago
Thank you so much friend! It is a very good feeling to hear that. Motivates me a lot :).
2 years ago
Great Instructable, I've bought a cheap 'leather kit' from Amazon with the plan to learn how to make things like this.
Reply 2 years ago
That is so awesome. Small projects are great to learn leather craft. Good luck friend.
Reply 2 years ago
Thank you, I need to get on and try the first project.
Reply 2 years ago
Just do it :). And practice a lot.
2 years ago on Step 10
Good job.
I was impressed with the chisel holder. I'm copying that, soon! Mine still live in the plastic holder they came in.
Reply 2 years ago
Thank you friend. Here is the tutorial i used for it: https://youtu.be/9UFg1skuglI
Reply 2 years ago
Thanks for the link. I make shotgun choke tube holders without any type of hold down for the top flap, and I make pen holders with a strap the top flap fits under ... less measuring and less cutting!
Reply 2 years ago
WOW, very cool. Would like to see your work.
Reply 2 years ago
Choke tube cases and pen cases.
Reply 2 years ago
WOW, really cool! Love it. Thank you for sharing your work with us.
Reply 2 years ago
Thanks, and you are welcome. Making stuff with leather is a fun hobby.
Reply 2 years ago
Don’t know why the pix is so fuzzy. It is in focus on my phone. :-(
Reply 2 years ago
If i click on your photo is all in focus and the quality is very good.
2 years ago
This is so beautiful and informative. I am gonna give it a try!
Reply 2 years ago
Thank you so much. Please, try it out.
2 years ago
Very good! I Like how simple yet useful it is
Reply 2 years ago
WOW, great to hear it. Thank you very much.
2 years ago
This is extremely good information and helpful to all that wish to learn. I'm one of those. Please never take the instructable down.... I have so much to learn that I have NO idea when I can get to this one in my VERY long list.
I never knew how ignorant I am... until I joined Instuctables. NTL, I'm glad I did!
