Introduction: Experiment With Piezoelectric Sensor
Hello friends, I hope you all will be fine. Today I share with you a piezo sensor it is a piezoelectric crystal.
I discuss with you a different experiment with a piezo sensor with energy generation In the previous post we discuss stepper motor control using Microcontroller and Keypad.
A piezoelectric sensor is a device that uses the piezoelectric effect,
- it can measure 1
- changes in pressure,
- 2 acceleration,
- 3 temperature,
- 4 force by converting them to an electrical charge
experiment with a piezoelectric sensor In this post we will discuss energy from piezoelectric sensors We have a piezo sensor Which we have used inside the thermopol sheet You see in the video as soon as we press the piezo sensor, energy produces from it Piezoelectric sensor has to press repeatedly if there is a big thing we do not have that energy product
Step 1: Foot Step Power Generation Using Piezoelectric Material
We have a piezo sensor Which we have used inside the thermophore sheet You see in the video as soon as we press the piezo sensor, energy produces from it Piezoelectric sensor has to press repeatedly if there is a big thing we do not have that energy product
for more details visit website
Step 2: Energy Produce From Piezoelectric Materials
PiezoElectric Sensor is a Good Voltage Producer
And energy can be produced from this Piezoelectric are small in many industries But this year it has not worked on the sensor. There is a lot of work going on this piezo We have also done many experiments with the piezo sensor We have used a boost circuit with which we will charge mobile If you look carefully in the video, energy produces from the Piezo sensor and mobile is charging too
Step 3: Different Piezoelectric Sensors
We have placed different Piezoelectric sensors inside a shoe, you can see in the picture
And all the Piezoelectric sensor used in sensor parallel not used in the series. As soon as we press or force the board, energy produces, we have used the LEDs in front of it, you can see working
Step 4: Amplifier Circuit
in step four we will use an amplifier for Piezoelectric sensor
The output of the piezo sensor is not so that we will use the amplifier It has fewer voltages, which are 3 volts and also 1 volt After using the amplifier, its power increases so that you can charge the mobile
If we do not use the amplifier then it will just turn on the LED And it has a special mechanism, then what works that other waves do not work
Right now we have added more details in these futures and uploaded what we have created
We have made a lot of educators here that the application of sensor which has been used too
Piezo sensor can be used with different microcontrollers, we have used it with arduino
If you do not understand anything, please comment you in the video and in the blog
