Explosion Box!
Intro: Explosion Box!
A box for any occasion. A box that does nothing but fall open. Who doesn't want one? Ok not very exciting, but hopefully the contents make up for it. A new way to present your present!
The Necessity List:
-Cardboard
-Wrapping paper or normal paper (Outside)
-Some thick paper, cardstock (For the inside)
-Box cutter and scissors
-Glue or tape
*Ribbons, bows, etc (for decoration)
*Disclaimer
This box does not literally explode. Please don't sue me. I don't really understand the etymology either.
STEP 1: Cutting
Cut
STEP 2: Wrapping
STEP 3: X
You can adjust the size by trimming to how much you want the wrapping paper to be exposed.
Be sure that the middle square is the EXACT same size as one of the wrapped squares or else the sides will not fall correctly.
The image below should clarify.
Cut out the cross following the red lines.
After having the cross cut out, crease the gray lines(shown below).
STEP 4: Coming Together
If everything is going well these should fold up and fall down.
STEP 5: Cap It
The cap will just be the large wrapped square with some smaller rectangles added.
Take any cardboard scraps you have and cut out rectangles the length of the square and maybe 1 inch in height.
Make 4 of these rectangles. Then wrap each one individually with wrapping paper.
(You can line the insides of your rectangles and large square with the thick paper you had to match the box and hide showing cardboard)
Assemble the cap by taping or gluing each rectangle to the outside of the square. Hot glue works well here.
Fold up the flaps and top it off with a cap and you're good!
STEP 6: Finish!
Well everything is complete now. The outcome is a multipurpose box. So gift it, put something in it, use it as decoration, anything.
Take your lunch in it, that can of Spam will work. Everyone will be envious when you pop that top. You may then proceed to take over the world with your can of Spam and your explosion box.
44 Comments
csnuey1 8 years ago
tkells 8 years ago
crazyshizyo. 8 years ago
SankalpK5 8 years ago
Jack Moran 9 years ago
Now to make 3 of them and put them inside each other....
kdeitrick 10 years ago
Mikimee 12 years ago
Shany120 12 years ago
Meganoki 13 years ago
lancon 13 years ago
JcBeaver 13 years ago
mojobo1 14 years ago
I noticed this instructable is the 9th result in a Google search for "Explosion box".
psphaxzor 14 years ago
timothymh 14 years ago
dan_peixoto 14 years ago
The main reason for that is the "smoke contraption". I think it would add a very nice efect to tha box!!
jeff-o 14 years ago
Rosemary700 14 years ago
Your version is much simpler and therefore more achieveable! Good for you!
grimdaddy 14 years ago
lancon 14 years ago
