Introduction: External Hard Drive From an Old Internal Hard Drive
This instructable shows the step by step process of making an external hard drive from an old internal hard drive. In addition, the methods I used to get the internal hard drive of an old laptop computer and to make the housing/casing of the DIY external hard drive are included. I hope this tutorial may help you ^_^.
Step 1: PREPARATION OF MATERIALS
Main Materials
1. Old internal hard drive
2. IDE/SATA to USB connector
If you will buy a connector, please be advised that it would be better to have your hard drive with you in order for you to test its suitability before purchasing it.
Optional 1 (harvesting internal hard drive from a laptop)
o Old laptop
o Phillip screw
o Box for screws
to avoid misplacing the screws
Optional 2 (for the casing/house of your hard drive)
· Ruler
· Pizza carton box
Use any materials that you desire however it is highly recommended to use something that can act like a cushion to protect the hard drive
· Glue gun
Use any adhesive that you want ^_^
· Scissor
· Pencil
Step 2: HARVESTING AN OLD HARD DRIVE
1. Remove the battery of your laptop
First, you need to remove any power supply which is connected to the laptop (yes, even the laptop battery). By doing this, you eliminate any possibilities for an electric shock to happen. This procedure is very important and is concerned about your safety.
2. Locate the hard drive of your laptop
Second, turn your laptop upside down then search for the location of its hard drive. Most of the time, you can see a rectangular shaped pattern (the shape of the hard drive) which tells the position of the hard drive.
3. Begin to disassemble the laptop
Lastly, you can now unscrew the part where the hard drive is located. Please be careful on removing the hard drive to avoid damaging it.
Step 3: MAKING THE CASING OF THE HARD DRIVE
1. Measure and cut
First, get the dimension of your hard drive. In my case, I have a hard drive with a width of 70mm, a height of 10mm, and a length of 100mm. I want to cover my hard drive by just rolling the pizza carton box on its body. In order to do so I cut a rectangle having a size of 105mm by 175mm.
(105mm is the length of the hard drive, 100mm, plus 5mm factor of safety)
(175mm is twice the width (70mm * 2 = 140mm) plus twice the height (10mm * 2 = 20mm) plus a factor of safety of 5mm)
2. Form the casing
Second, envelope the body of the hard drive with the pizza carton box. I used glue gun as an adhesive to make sure that it will not easily break apart.
3. Design and finish
Lastly, furnish your work by putting some decorations on the cover. You can draw, paint, or color the cover. In my case, I put my name on the center front and a sticker below it. Also, I used plastic cover to make it more presentable.
Step 4: TESTING
You can now test your hard drive! I congratulate you for being patient and persevering to accomplish this task. I hope you like this tutorial and please be informed that I am grateful to share this. Please comment/subscribe/like/share this. Thanks ^^.
EDIT:
Thank you for ИванИ11 for reminding that you need an exhaust (or any mechanism that will prevent entrapping the air inside the casing). One way of doing this is to have some tiny holes on your casing.
