Introduction: Eye Glasses Case Tutorial
Make yourself an glasses case to protect your specs!
9″ by 9" piece of fabric. (I used embroidered linen.)
Needle, thread, pins.
Step 1: Pin and Quilt the Outer Fabric
Step 1: Pin the outer fabric and the cotton batting together. Sew the two layers together, using vertical lines spaced about 1 inch apart.
Step 2: Trim the Outer Fabric
Step 2: Use a rotary cutter and ruler to square up the fabric. Trim the edges so that the finished piece measures 8.5" by 8.5".
Step 3: Fold and Sew
Step 3: Fold the outer layer in half, right sides together. Pin, and sew along the long side and 1 short side, using a 1/4 inch seam allowance.
Step 4: Turn Right Side Out
Step 4: Turn the fabric right side out. Use a long, blunt object (like knitting needles) to poke out the corners.
Step 5: Fold and Sew Lining Fabric
Step 5: Time for the lining. Fold the lining fabric in half, right sides together. Sew along the long side, using a 1/4 inch seam allowance. Sew along 1 short side, but leave a small opening. (about two fingers worth)
Step 6: Pin Them Together
Pin the two pieces together and stitch around the opening.
Step 7: Pull It Through
Step 7: Pull the outer piece out through the opening in short side of the lining fabric. Don’t tuck the lining in just yet.
Step 8: Stitch the Lining Closed
Step 8: Hand stitch (or let's be honest, machine stitch) the opening in the lining fabric closed.
Step 9: Tuck in the Lining
Step 10: Tuck the lining in, again using a long blunt object to poke out the corners.
Ta da! You did it.
*For personal use only, please.
13 Comments
12 years ago on Step 9
Can't wait to try this! My Daughter and I love to sew together, and this is a perfect project for us:)
12 years ago on Introduction
Really nice, I like the fabric you chose. But I want to know how did you embroidered the glasses? Thanks
Reply 12 years ago on Introduction
I just googled "sunglasses coloring pages," picked the one I liked best, printed it out at the size that I wanted and cut them out. I applied applique adhesive (can be found at JoAnns Fabrics) to the back of the yellow fabric and the gold fabric I used for the lens. I then pinned the sunglasses cut out to the yellow fabric and cut it out, and then cut out the lens in the gold fabric. Next, I ironed the design on the fabric. (I did this after I sewed the batting onto the outer fabric and before sewing the lining to it) The last thing I do for appliques is to make small stitches with colored embroidery thread around the edges to make sure it doesn't peel off. Here is a close up picture of the stitching.
Hope this is a good explanation!
Thanks! Your pic helped a lot! I really love the fabrics you chose. When I'm done I'll put a pic here too. I live in Brazil, and I've never seen this applique adhesive in the craft's stores here but I just used regular white glue and it worked just as fine.
I definitely want to see when you get done!
I just did it by hand with a needle and some embroidery thread. The thread I buy is pretty thick, six strands twisted together.
Here are the two I've made. I even added magnets inside the lining on the second one to keep it closed. Thanks for your wonderful tutorial!
13 years ago on Introduction
Too bad I only have one pair of glasses :(
Reply 13 years ago on Introduction
U can still use it even tho u only have 1 pair. U can store them there @ nite when u take them off 2 go 2 sleep. My nite stand usually gets cluttered up & a case usually keeps them clean & safe from gettin scratched :-)
Thanks, I need to make a case for my safety glasses at work!
Love the tute.
Very nice, you REALLY take care of your glasses.
Looks great! I love the bonus eyeglasses label on the outside.
