Introduction: Ez 12v Work Light
I have a service truck which I use 24/7 for on call work. the issue is my flood lights are mounted to the truck and my shadow makes things difficult at times. so I used a 12v flood light and made a mobile work light.
Step 1: Assembly
you will need the following things:
12v flood light (I'd use LED but my boss is cheap)
used no good car disc brake rotor (free at most auto repair shops if you ask)
2 wire extension cord (length is up to you)
nut and bolt
electrical tape
wire strippers
razor blade (optional makes things easier)
nut and bolt
electrical tape
wire strippers
Step 2: Assembly
cut the female end of the extension cord off at about 1-2' long.
use the razor blade to strip the cords orange(or what ever color ext cord you have) insulation off about 2-3" from the cut end
strip the two wires (black and white)
attach the white wire (ground wire) to a ground or existing bolt on the frame
then attach the black wire (hot lead wire) to you switched power source. in my case a light that was already mounted
then bolt your 12v light to the disc brake rotor in one of the holes used for the studs
next hook the hot lead wire (black wire) to the hot lead wire in the light
now hook up the ground wire (white wire) to either the lights ground wire or if the light is grounded via the mounting hardware use the not and bolt to bolt the ground to the rotor
tape up all of the connections you've made to prevent shorting
wrap the cord around the lights mounting bracket and zip tie it so it won't pull the wires from each other
Step 3: Test Light
now that its built plug it in and test to make sure it works. if it doesn't check your connections and grounds then check the switches fuse (I hope you put it on a switched fuse! ;) )
if you did things correctly you should have a mobile work light with a solid base. I plan to bolt up a bike hanger hook on my truck for easy storage of the light when its not in use.
good luck and thanks for looking and remember.....always experiment!
