Introduction: F-Roof: a Multi-function, Single-layer Roof
About: Started with Computer Algorithms in high school, then with Visual Programming, then with Genetic Programming, then with Optical Computing, and now with robots.
The purpose of the F-Roof is to:
  1. Protect the house from rain and snow.
  2. Provide electrical energy to the house.
  3. Provide food (vegetables) for the house's inhabitants.
  4. Use structure as function (solar panels and plants' pots are the roof).
Why F-Roof?
Because:
  1. Most of the roofs have a single function: to protect the house from rain and snow. We want more from a roof!
  2. Ground-level soil should be used for growing trees, not vegetables. Vegetables have small roots that require less soil.
  3. Existing roof-gardens have too many unnecessary layers, thus being expensive. One layer should be enough.
  4. Soil on the roof provides thermal insulation, so the attic becomes less hot during summer.
  5. The air behind solar panels could be circulated (with a fan) so the panels' temperature will be reduced and their efficiency will be increased.
  6. Wood should not be utilized for construction purposes. Trees are more important than for building houses!
  7. Utilize a minimal amount of materials (solar panels and plant pots have a dual purpose: they provide energy/food and make the roof's structure).
Step 1: Cut
Cut bars to the required length and angle.
Step 2: Weld
Weld trusses
Step 3: Lift
Lift trusses to the top of the house
Step 4: Connect
Connect trusses with T40 metal profiles
Step 5: Solar Side
Place solar panels on the top. Use silicon glue between them.
Step 6: Gutters
Cut gutters to length
Step 7: Plant Vegetables
Do this at ground level. It is easier this way.
Step 8: Stairs
Cut 2 stairs on which the gutters are placed.
Step 9: Balustrade
Build a balustrade to support you during garden maintenance.
Step 10: Lift Gutters
Lift gutters on stairs. Use bituminous tape to prevent water leakage.
Step 11: Result From Inside Roof
Solar panels and gutters seen from inside the roof.
Step 12: Result From Outside Roof
Solar panels and gutters seen from the outside of the roof.
