Introduction: F150 2.5" Leveling Kit Install
This will be a step by step installation for the Rugged Off Road 2.5" leveling kit for the 2015-2020 F150
The kit we installed: https://amzn.to/33zBHAN
Tools need:
8, 10, 13, 18, 19, 22, 27 MM sockets
8, 15, 19 mm wrenches
Pry bar, floor jack and jackstands
2 pipes or adjustable wrenches
Step 1: Vacuum/brake Lins
remove all bolts and clips securing the 4WD vacuum line and brake lines to give you slack to drop the spindle assembly
Step 2: Ball Joint and Tie Rod
Loosen the upper ball joint with a 19mm wrench and 8mm wrench or socket. Then remove the tie rod from the spindle
Step 3: Strut Nuts
Remove the 3 15mm nuts securing the top of the strut
Step 4: Axle Nut
Remove the dust cap with vice grips then remove the 13mm axle nut
Step 5: Sway Bar End Link
Disconnect the sway bar end link by removing the 19mm nut
Step 6: Control Arm
Remove the 2 nuts securing the strut to the lower control arm, then loosen but dont remove the front and rear 27MM lower control arm nuts. This will allow the control arm to freely move to remove and install the strut,
Step 7: Remove Strut
Remove strut by lowering the control arm, but be careful not to put too much tension on the brake lines.
Step 8: Reconnect Upper Balljoint
Now that the strut it out, reconnect the upper ball joint to prevent damage, while you install the spacer.
Step 9: Install the Spacer
Install the spacer, it can only go on one way
Step 10: Correct the Studs
The studs are now angle approx 15 degree in the wrong direction now that the spacer is install. Spray lubricant on the bushing, put 2 pipes on the studs and rotate them to make then angled in the opposite direction approx 15 degrees
Step 11: Reassemble
The strut can now go back in the truck, carefully lower the spindle and lower control arm again to allow room for the strut, be careful of the brake lines! Reassembly should be pretty strait forward, the only trick is to use a pry bar to pull down on the upper ball joint to reconnect it to the spindle.
Tighten the 27mm lower control arm nuts after the wheels are install and the truck is on the ground.
Done!
