Introduction: FFF 3D-Print Mega Sumo Robot
About: I Love Robot Sumo!!! If you’d like to send me a message, please use Facebook. I might take a while to notice messages sent through Instructables.
This is a mega sumo robot that can be made with an FFF 3D printer and some hand tools.
See here for the Robot Sumo Tournament.
Conventional mega-sumo robots require machine tools to process metal and CFRP, and this has been a major obstacle to making mega-sumo robots. So I designed a machine tool-free mega-sumo robot that you can build in your own living room. I hope that this initiative will increase the number of participants in Mega Sumo Robot tournaments.
I also hope that you will design and share your own 3D-Print Mega Sumo Robot.
CAUTION: This robot uses powerful magnets, high-powered motors, sharp knives, and lithium-ion batteries. These are very dangerous if handled incorrectly, so please do not build this robot if you do not have the expertise to handle them.
Only a brief explanation follows. Please refer to the 3D data for the basic assembly method.
3D printer
  1. Print range of 200 x 200 x 200 (mm) or more.
  2. The printer must be able to print ABS filament.
Hand tools
  1. Drill Bit 3.0mm
  2. Drill Bit 3.2mm
  3. Drill Bit 4.0mm
  4. Drill Bit 5.0mm
  5. Drill Bit 5.1mm
  6. Drill Bit 6.0mm
  7. Hand Drill
  8. Screwdriver Phillips No0
  9. Screwdriver Phillips No1
  10. Screwdriver Hex 1.5mm
  11. Screwdriver Hex 2.5mm
  12. Diamond Precision File
  13. Precision File
  14. Precision Side Cutter
  15. Snap-off Utility Knife
  16. Hot Melt Glue Gun
  17. Sand Paper
  18. Soldering Iron
  19. Machine Vise
  20. Scissors
  21. Metal Cutting Shears
  22. Putty Knife
  23. Cut-resistant gloves
Purchased parts
  1. 3D Printer Filament ABS
  2. 3D Printer Filament Nylon
  3. Glue
  4. Double-sided Tape
  5. Brake Parts Cleaner
  6. PERMATEX Screw Lock Red
  7. Soldering Wire
  8. Parts described in BOM
Step 1: 3D Printing
Create STL data from 3D data [FFF 3D-Print Mega Sumo Robot Ver1.0 v2.f3d].
Print the parts.
Please refer to the figure for the molding direction of the 3D print parts.
The gear uses Nylon filament. Others use ABS filament. See BOM for details.
Be careful not to warp the 3D printed parts.
Make sure the 3D printed parts are sized according to the data. Adjust the 3D printer if the size of the data and the output part are different.
  • 3D printer
  • 3D Printer Filament ABS
  • 3D Printer Filament Nylon
  • Putty Knife
  • Precision Side Cutter
  • Drill Bit 3.0mm
  • Drill Bit 3.2mm
  • Drill Bit 4.0mm
  • Drill Bit 5.0mm
  • Drill Bit 5.1mm
  • Drill Bit 6.0mm
  • Hand Drill
  • Precision File
Step 2: Cut Off the Protrusion of the Blade Base.
Cut off the protrusion of the Blade base.
Then smooth the surface with a file.
  • Precision File
  • Blade base (1)
Step 3: Glue the Magnets to the Blade Base
Sanding the magnet and blade base pocket.
Apply glue to both the blade base and the magnet. and glue it.
The magnetic pole pattern is either all N or all S.
  • Glue
  • Sand Paper
  • Magnet D15t2 (8)
  • Blade base (1)
Step 4: Glue the Magnet to the Frame
Sanding the magnet and frame pocket.
Apply glue to both the frame and the magnet. and glue it.
The magnetic pole pattern alternates between N and S.
  • Glue
  • Sand Paper
  • Outer frame R (1)
  • Outer frame L (1)
  • Inner frame R (1)
  • Inner frame L (1)
  • Magnet D20t5 (14)
Step 5: Glue the Magnet to the Cover
Arrange the magnetic pole pattern so that the Top cover and the Stopper attract each other.
Once the magnet is fixed, fix the top cover and stopper with the shaft.
  • Glue
  • Sand Paper
  • Top cover (1)
  • Stopper (1)
  • Magnet D8t3 (2)
  • Stainless steel (303) precision shaft φ3L45 (1)
Step 6: After Installing the Nut, Fix It With Hot Bond 1
After installing the nut, fix it with hot bond.
Once the glue has hardened, cut off any excess glue.
  • Hot Melt Glue Gun
  • Snap-off Utility Knife
  • Cut-resistant gloves
  • Blade base (1)
  • No5 blade (1)
  • M2.6 Nut 3 types (5)
  • Screw_M2.6 Plate No. 0 Type 3 L5 (5)
Step 7: After Installing the Nut, Fix It With Hot Bond 2
Attach the motor holder to the inner frame.
  • Hot Melt Glue Gun
  • Screwdriver Phillips No0
  • Screwdriver Hex 2.5mm
  • Outer frame R (1)
  • Outer frame L (1)
  • Inner frame R (1)
  • Inner frame L (1)
  • Center frame (1)
  • M2.6 Nut 3 types (8)
  • Screw_M2.6 Plate No. 0 Type 3 L10 (8)
  • Motor holder (2)
  • M3 nut Type 3 (6)
  • Hex socket head bolt M3x30 (6)
Step 8: Stick the Shim Plate to the Blade Base
Cut the Shim plate with Metal Cutting Shears.
File the cut surface.
Place the Shim plate in the machine vise. Then bend the plate slightly.
Apply double-sided tape to the Shim plate. Then stick it on the blade base.
  • Machine Vise
  • Double-sided Tape
  • Metal Cutting Shears
  • Shim plate hardened steel t0.3W100L200 (1)
  • Blade base (1)
Step 9: Cut the Rubber Pipe and Attach It to the Wheel
Cut the rubber pipe.
Clean the inside of the cut rubber pipe with brake cleaner.
Assemble the cut rubber pipe and wheel.
Glue the wheel and rubber pipe.
  • Brake Parts Cleaner
  • Glue
  • Wheel (2)
  • Natural Rubber (NR) Pipe Hardness 60 [Set of 2] (1)
Step 10: Assemble the Gear ASSY_A
Fit the small gear into the hole of the large gear.
If your gear is wobbly, resize your 3D print.
  • Gear ASSY_A _small gear (2)
  • PS1-40J18 Spur gear (2)
Step 11: Install the Bearing
Install bearings on gears and wheels.
  • Wheel (2)
  • Bearing D13d6t5 (4)
  • Gear ASSY_A (2)
  • Bearing D10d6t3 (4)
  • Gear assembly_B (2)
  • Bearing D10d5t4 (4)
  • Gear m1Z16t12d8 (2)
  • Bearing D8d4t3 (4)
  • Spacer_3D printing_D7.8d5.8t4 (2)
Step 12: Install the Gear and Set Screw on the Motor.
Clean motor shaft and gear holes.
Apply Screw Lock to the motor shaft. and attach the gear. At this time, be careful not to let the Screw Lock get into the motor bearings.
At this time, secure a gap between the gear and the motor case. If there is no clearance, the gear will not rotate properly.
Stand the motor and wait for the gear to be fixed.
Install the set screw in the screw hole of the motor.
  • PERMATEX Screw Lock Red
  • Screwdriver Hex 1.5mm
  • MAXON DCX35L (2)
  • Gear m1Z14t12d6 (2)
  • M3L5 Stainless Hex Socket Set Screw/Flat Point Nissan Screw (12)
Step 13: Soldering the Harness to the Motor
Soldering the harness to the motor.
  • Soldering Iron
  • Soldering Wire
  • MAXON DCX35L (2)
  • Silicone cord 16AWG (1)
  • XT30 connector female (2)
Step 14: Install the Set Screw and Shaft on the Center Frame
Insert the set screw into the Center frame.
Insert bolts and nuts.
Center the shaft in the Center frame. Then fix it with a screw.
  • Center frame (1)
  • Linear shaft φ6L200 (1)
  • Linear shaft φ5L200 (5)
  • Linear shaft φ4L40 (1)
  • Stainless steel (303) precision shaft φ3L145 (1)
  • M3L5 Stainless Hex Socket Set Screw/Flat Point Nissan Screw (5)
  • M2 nuts Type 3 (1)
  • Hex socket head bolt M2x10 (1)
Step 15: Make the Blade Safe
Sharpen and round the edge of the blade with a file.
  1. Diamond Precision File
  2. No5 blade (used, rounded edge) (2)
A new online shop selling No 5 Blades has just launched.(2025.08.01)
Check it out at: https://robomaniacs.ro/product/japanese-sumo-mega-blade/
Step 16: Assemble the Motor Driver
Assemble the Motor driver assembly according to the diagram and circuit diagram.
Write the program in the attached file [RC_Read3.ino] to the Arduino micro.
Be sure to test run the Motor driver assembly before incorporating it into the robot.
  • Soldering Iron
  • Soldering Wire
  • Precision File
  • Machine Vise
  • Screwdriver Phillips No1
  • Substrate base (1)
  • Board cover (1)
  • Double-sided through-hole universal board 4*6 (1)
  • Photocoupler TLP785 (GB rank) (4)
  • Pololu High-Power Motor Driver 36v20 CS (4)
  • NPN digital transistor DTC114EL (2)
  • Capacitor 63V100uF (5)
  • 9V, 600mA Step-Down Voltage Regulator D36V6F9 (1)
  • Arduino Micro (1)
  • Screw_Iron + pan B tight 2x6 (4)
  • Screw_Iron + pan B tight 2x10 (8)
  • XH connector post with base 5P (2)
  • XH connector housing 5P (2)
  • Contacts for XH connectors (14)
  • Contact N for XH connector (14)
  • XH connector post with base 4P (2)
  • XH connector housing 4P (2)
  • wire cord for XH connector (1)
  • 3-pin connector for radio control signals (2)
  • 3 wire cord for radio control signals (2)
  • Radio control receiver (1)
  • Anderson Connector 1327Red (1)
  • Anderson Connector 1327Black (1)
  • Anderson Connector Contact 15Amp (2)
  • XT30 connector male (2)
  • Breaker fuse 40A (1)
  • Silicone cord 14AWG (1)
  • Copper wire #16*1m (1)
Step 17: Attach the Connector to the Battery
Attach the connector to the battery as shown.
CAUTION: Never short circuit the battery. A fire will occur.
  • LiPo 1300mAh 3S (2)
  • LiPo 1300mAh 2S (2)
  • Anderson Connector Contact 15Amp (4)
  • Anderson Connector Contacts 30Amp (2)
  • Anderson Connector 1327Black (2)
  • Anderson Connector 1327Red (4)
Step 18: Assemble the Robot.
Assemble the robot by referring to the video.
