Introduction: FISH SMOKE HOUSE
smoking you fish in your back yard
Step 1: Step # 1 Making Fishing Hangign Racks
use 1" x2" x 36" long pine wood to make you fish hanging rack
you will ned as many as 3 per raw or more
use D-6 or D-8 common nails or better if you can get ss- nails from a marine store
pre-drill with a small diameter drill bit than the nail you are using at an upward angle - so you can hang the fish from it
the opposite side will have raw's fo pine wood notched to hold the fish hanging rack firmly in the smoke-house
Step 2: Step # 2 Build the Flor and Teh Sides
build a 24' x 36' floor - tung and grove is desired in pine or cedar wood
assembled on the side with the peak at 6 feet high
this will all sit on a cement block form later
Step 3: Step # 3
install back wall and sides
Step 4: Step # 4
install pitched roof - tung, and grove and allow some extra hang on the outer edge brace as needed
Step 5: Step# 5
install front panels hinge extra as shown
Step 6: Step # 6
install end panel and duct tube to provide the smoke into the smokehouse
the whole thing will be placed on the masonry blocks as shown
you can cald the surface with nice decorative bricks
Step 7:
the house is sort of complete attach the duct to the source of smoke which could be a small metal box or round drum that you can burn oak wood
instal temperature gauge on the lower side of the front panel and another one at the higher side so you can get a good reading of the inner temperature of the smokehouse --- you just drill a hole and attach the nut provided and its ready to give you the readings
Step 8: Step # 8 Start Smoking
enjoy you smoked fish
