Introduction: FPGA Cyclone IV DueProLogic Controls Arduino
In this tutorial, we are going to develop a platform where FPGA DueProLogic communicates with Arduino Due.
Four tasks will be demonstrated.
(A) PC remotes FPGA DueProLogic
(B) FPGA DueProLogic controls the LED-13 on Arduino Due
(C) Arduino Due sends ultrasonic sensor data to FPGA DueProLogic
(D) FPGA DueProLogic transmits data to PC
Video Demo:
Lab menu: https://roywchpi.blogspot.com/2020/06/11-fpga-controls-arduino.html
Step 1: Build Electronic Circuit
Step 2: Edit Verilog Code As Follow
When you buy the FPGA DueProLogic, you should receive a DVD. After you open "Projects_HDL", you should see verilog code
//Arduino Connections
assign LEDExt = XIO_5[5]; //XIO_5 -- UB59 -- D15
assign XIO_1[3] = start_stop_cntrl; //XIO_1 -- UB3 -- D11
assign c_enable = XIO_5[2]; //XIO_5 -- UB57 -- D17
assign data_from_arduino[7] = XIO_6[18]; //XIO_6 -- UB40 -- D40
assign data_from_arduino[6] = XIO_6[17]; //XIO_6 -- UB39 -- D39
assign data_from_arduino[5] = XIO_6[16]; //XIO_6 -- UB38 -- D38
assign data_from_arduino[4] = XIO_6[15]; //XIO_6 -- UB37 -- D37
assign data_from_arduino[3] = XIO_6[14]; //XIO_6 -- UB36 -- D36
assign data_from_arduino[2] = XIO_6[13]; //XIO_6 -- UB35 -- D35
assign data_from_arduino[1] = XIO_6[12]; //XIO_6 -- UB34 -- D34
assign data_from_arduino[0] = XIO_6[11]; //XIO_6 -- UB33 -- D33
Step 3: Compile Verilog Code
Press "Start Compilation" in Quartus, no error message should be generated. If you receive error message about multiple pins. Go to Assignments -> Device -> Device and Pin Options -> Dual-Purpose Pins -> change the value of the appropriate pin to "Use as regular I/O".
After compilation, you should get pof output file directly. If you get sof output file only, click "File" in Quartus -> "convert programming files". Change the settings which are marked by red boxes.
Press "Programmer" in Quartus, update the pof file and then click "Start"
Step 4: Upload Arduino Code
#define COMMANDDELAY 10 // ms to wait for the filling of Serial buffer
#define COMBUFFERSIZE 3 // Size of buffer for incoming numbers
int startStopBit = 0; int count = 0;
int echoPin = 2; // Echo
int trigPin = 3; // Trigger
long duration, cm, inches;
int inPin11 = 11; //Input
int ledPin = 13; //Due Output
int LEDExt = 15; //Output
int C_Enable = 17; //Output
int new_value = 0x00000000;
int data_top_2bits = 0;
int data_bottom_6bits = 0;
int data_to_DPL = 0;
int newP = 500;
char commandBuffer[COMBUFFERSIZE+1];
// Fills the given buffer with bufferSize chars from a Serial object void fillBuffer( \ char *buffer, \ byte bufferSize, \ HardwareSerial* serial = &Serial );
void setup()
int k ; //Set pins D33-D41 as outputs
for( k = 33 ; k <= 41 ; k++ )
pinMode( k, OUTPUT ) ; // Sets Port C2-C9 to output pins
// Set the output pins in the Output Write Enable Register
REG_PIOC_OWER = 0x0000037E ;
// Disable writing to all other pins on the same port-
REG_PIOC_OWDR = 0xFFFFFC81 ;
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(C_Enable, OUTPUT);
pinMode(ledPin, OUTPUT);
pinMode(LEDExt, OUTPUT);
pinMode(inPin11, INPUT);
pinMode(motorPin, OUTPUT);
//randomSeed(analogRead(1));
Serial.begin(115200);
void loop ()
int i ; //Sample the Start/Stop switch //from the EPT-4CE6-AF
startStopBit = digitalRead(inPin11);
Serial.println(startStopBit);
delay(newP); //Delay in ms
if(startStopBit==0)
digitalWrite(ledPin, LOW);
delay(1000);
if(startStopBit==1)
digitalWrite(ledPin, HIGH);
delay(1000);
digitalWrite(trigPin, LOW);
delayMicroseconds(5);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
cm = (duration/2) / 29.1; // Divide by 29.1 or multiply by 0.0343, this is physics
new_value = cm;
delay(1000); //Map the the transfer byte to pins available on the DueProLogic
data_top_2bits = (new_value & 0x000000c0)<<2;
data_bottom_6bits = (new_value & 0x0000003F)<<1; //Or the re-mapped bits together and use the ODSR
data_to_DPL = data_top_2bits | data_bottom_6bits;
REG_PIOC_ODSR = data_to_DPL; //Set the Write Enable Pin High
digitalWrite(C_Enable, HIGH);
//Set the LED Pin High
digitalWrite(LEDExt, HIGH);
//Set the LED Pin Low
digitalWrite(LEDExt, LOW); //Set the Write Enable Pin Low
digitalWrite(C_Enable, LOW);
if ( Serial.available() > 0 )
// Read the incoming byte
char theChar = Serial.read();
// Parse character
switch (theChar)
case 's': // 's' for setting time between samples // Wait for COMMANDDELAY ms
delay(COMMANDDELAY);
fillBuffer( commandBuffer, COMBUFFERSIZE );
// Convert buffer to integer //commandBuffer = "32";
newP = atoi( commandBuffer );
// Display moving status indicator
Serial.print("Setting the EPT prescaler to: ");
Serial.println(newP);
//Call set timing with newP //setIntervalTiming(newP);
break;
default: // Display error message
Serial.print("ERROR: Command not found, it was: ");
Serial.println(theChar);
break;
//----------------------------------------------------------------------------- // fillBuffer //----------------------------------------------------------------------------- // Fills the given buffer with bufferSize chars from a Serial object
void fillBuffer( char *buffer, byte bufferSize, HardwareSerial* serial )
{ // Clean buffer
memset( (void *)buffer, '\0', sizeof(char) * bufferSize );
byte limit = ( bufferSize < serial->available() ) ? bufferSize : serial->available();
// Fill buffer
for ( byte i = 0; i < limit; i++ )
buffer[i] = serial->read();
Step 5: Connect FPGA to PC
You have to Install Visual Studio C#. Then open the C# file in Active_Host (DVD).
Create ON and OFF buttons in GUI interface with help of C# Toolbox.
//On button:
private void btnWriteByte_Click(object sender, EventArgs e)
int address_to_device;
address_to_device = Convert.ToInt32(tbAddress.Text); EPT_AH_SendTransferControlByte((char)2, (char)1);
//OFF button
private void btnTransferReset_Click(object sender, EventArgs e)
address_to_device = Convert.ToInt32(tbAddress.Text); EPT_AH_SendTransferControlByte((char)address_to_device, (char)0);
The char 0 and 1 determine the status of "start_stop_cntrl" in FPGA
When you compile and build the C# projects, exe file will be generated in C:\Visual Studio 2019\Data_collector\bin\x64\Release.
Step 6: Let's Try It
When you click "On", your PC sends signals to the FGPA to light up LED-13 on Arduino Due. Meanwhile the ultrasonic sensor transfers the data to the FPGA and then the data will be appeared on your PC.
