Introduction: FUN Gloop Corn Flour Experiment
Step 1: Ingredients
Small amount of water
Small shallow bowl
Regular cornflour (powder)
Tablespoon
Step 2: Adding the Cornflour
Add approxaty 2-3 tablespoons of cornflour into the bowl.
Step 3: Add the Water
Add approximately 3 and a half tablespoons of water to the corn flour
Step 4: Mix Well
Mix well till all the corn flour has been removed from the sides of the bowl
Step 5: Done
Squizze ALITTLE bit and open your hand
It should start to melt
Then squizze it again the repeat
CAUTION
DO NOT TROUGH DOWN DRAIN THROUGH IT IN THE BIN. if you crumble it just put a TINY TINY amount of water i it and mix bit if tou crumble to nuch, it doesnt work. if you get the mix in your hair, IT IS FINE. Just
Rinse it In some water because it DESOLVES very very quick so don't worry
Same go for your clothes
Only use on lamanate tables/counters
Do not use on carpet.
If mix gets on floor,
Either use a damp cloth to remove or use hands!
You can eat alittle bit if you want
