Introduction: Fabulous Fabric Plant
Make a plant that will never die using old scraps of fabric and paint! Perfect if you have a black thumb like I do!
Step 1: Watch the Video Tutorial Here!
Step 2: You'll Need
Iron
E-6000 Stitchless
Americana Multi-Surface Satin in Chick and Turf Green
White cotton fabric
18 gage wire
Paintbrushes
Decorative pot
Styrofoam block
Wire cutters
Step 3: Make the Leaves
Cut several different sizes of long triangles that are 3'' at the base
Press them in half
Add E-6000 Stitchless to the inner edge and press closed
*Make sure not to close the base of the triangle
You will need about 30 triangles depending on the size of the plant you want
Step 4: Paint and "plant"
Paint the center of each leaf on both sides with the color of your choice *I used Turf Green and lightened it with white
Paint the edges in another color *I used Chick
Cut wire pieces 3" longer than each leaf and insert into the leaves
Shape the Styrofoam block to the size of your pot
Add the leaves to the block and create your plant
