Introduction: Face Visor
Hi
In this instructable I will show you how to make a quick and easy Face Visor for protection from Covid 19. Read & Enjoy!
You will need:
A Black Marker Pen
Some Clear Plastic
Hot Glue
A Ruler
Scissors
Step 1:
Take your clear plastic, I didn't have any so I used laminated, laminating pouches with nothing in them to make the plastic, cut the pieces I had one piece that was 21.5 x 23 cm and two other pieces for the head that were 2.5 x 30 cm.
Step 2:
Now mark two small dots with a pen in the top left and right hand corners roughly 1.5 cm in from each side. Put a small amount of hot glue on each dot and press one end of each long strip onto the glue.
Step 3:
Now hold the unfinished visor to your face and bend the head ties round the back of your head, there should be an overlap of the ties. Hold the ties in position and remove the visor carefully from your head lift the top overlap tie and mark a small dot where your finger is on the underneath strip, this shows you where to put the hot glue so that it is tight enough when worn.
Place some more glue on the dot and place the end of the other strip on the glue, hold the strips together until firm.
Step 4:
Now pull away the the underneath strip and make a mark on the end careful not to separate the glue joining the two pieces further up the strip. Put some glue on that dot and press it onto the above strip. Hold together until firm, and there you have it a simple and effective face visor made in four simple steps!
