Introduction: Face to Face Wheelchair
A set of add on handles for wheelchairs that make it easier to enjoy the talk
while taking a walk with your loved one.
Step 1: Choose Your Type of Wheelchair and Connector
Our add-on handles are designed to fit a verity of wheelchair designs.
Make sure you choose the right type of connection that fit your needs.
Step 2: Folding of the Handles
Bend the 720 mm metal pipes for handles according to the angles here
*If the place of connecting the handles to your wheelchair is not vertical, make sure to adjust this bending angle accordingly.
Step 3: Drilling
Drill a 6mm diameter hole in the marked place both on the wheel chair and on the handle pipe
Step 4: Printing
3D print the handle stoppers file attached
(STL file name : Handle stoppers) Using a bit of pressure, place at 3 cm height on the handle pipe .
Step 5: Inserting
Insert the pole push button spring into the handle pipe
Link for pole push spring - click here
Step 6: Basic Handles Connector- Done !
Place the handlebar grips and insert the handle pipe into the wheelchair .
Enjoy the walk with your new Face to Face handles!
Link for purchasing handlebar grips- click here
Step 7: For Add-on Connectors Only
Drill a 6 mm Diameter hole in the 150 mm length pipe
Step 8: 3D Printing
3D print the connector part (STL part name: Add On Connector)
Step 9: Placing
Using the metal bands, connect the 3D printed connector part and the 150 mm metal pipe to the wheelchair.
Link for purchasing metal band - click here
Step 10: Enjoy!
Insert the handles and enjoy the walk with your new Face to Face handles!
