Introduction: Facebook Fan Count
Update: 26.09.2019 - Time flies and technology changes. Since I created this project, Facebook has changed its APIs and APP setup. So the step to create a Facebook APP has expired. Today I no longer have access or opportunity to follow up this step. Still, I leave this tutorial as an inspiration to create something similar, even though it has expired. Good luck with your projects and leave a comment if you have made something similar.
Inspired by Becky Stern's YouTube Subscriber Counter, I wanted to make a display of the number of likes for a Facebook page. My goal with this project was to bring out the number of fans from a Facebook page. Not any one but one I administer. To code C is not my field so I started with a lot of trial and error. But ended up with a result that worked.
This is what you need for this project:
Software
Facebook APP https://developers.facebook.com/
Facebook fingerprint https://github.com/gbrault/esp8266-Arduino/blob/master/doc/esp8266wifi/client-secure-examples.md#how-to-verify-servers-identity
Arduino IDE https://www.arduino.cc/en/Main/Software
Libaries for Arduino IDE
WIFI ESP8266 https://github.com/esp8266/Arduino
Seven segment display https://github.com/bremme/arduino-tm1637
JSON https://github.com/bblanchon/ArduinoJson
Hardware
Ikea Ribba 000.783.34 (or another frame to hold the project) http://www.ikea.com/no/no/catalog/products/0007833...
NodeMCU (mini) https://www.banggood.com/Mini-NodeMCU-ESP8266-WIFI...
Display https://www.banggood.com/RobotDyn-LED-Display-Tube...
Tools
Rotary tool or something to make a square hole in the backplate of the frame.
Step 1: Create Facebook APP
This can be done at developers.facebook.com. After the APP is created, note the App ID and App Secret. You'll need this in the code.
Wanna test the access for your APP? Head over to https://developers.facebook.com/tools/explorer/
Enter the following: AAA?access_token=BBB|CCC&fields=fan_count
- AAA = Facebook Page ID or name,
- BBB = App ID
- CCC = App Secret
Note the | (pipe) between App ID and App Secret.
Step 2: Hardware – Electronics
Now over to the fun part. I have used a NodeMCU Mini. These are available in various varieties and price ranges in a variety of online stores and on eBay. There were two reasons I chose a mini. The first reason was that I already had a lying one in my drawer. The other reason was that it is small and takes up little space in a picture frame.
I bought a display consisting of four segments mounted on a board of electronics so I only need to use four of NoceMCUen's IOs.
NOTE: NodeMCU has only 3.3V output while the display will preferably have 5V. It will work with 3.3V but will light slightly. Fortunately for me my NodeMCU gives 5V outputs via VIN.
As you can see on my somewhat blurry image the VIN, VCC and data pin are aligned. This means I don't need any wires between the NodeMCU and display. Just slide the boards together and add some soldering.
- VIN --> 5V
- GND --> GND
- D4 --> DIO
- D3 --> CLK
Disclaimer: I do not take responsibility for connecting your equipment together and any damage that may occur on your equipment if you follow my example. Fortunately, this setup seems to work me.
Step 3: Hardware – Frame
I bought a Ikea Ribba 000.783.34. The reason why I bought this frame is that it has a deep frame. Then I can easily fit the display and the electronics.
The picture above shows that I have made holes for the display. I made a template that I attached to the backplate and marked where I wanted to have the display. Then I used a rotary tool to make the hole.
The next step was to tweak the placement of the display and make it as bright as possible through the paper in front. As you probably understand, I did not start with the frame itself. For it would be useless to build a display in a frame if I did not have a number to display.
After I had created a Facebook APP, I had to put myself into a somewhat unknown world. I do not know much about programming C ++. But ended up with a satisfactory result after much trial and error.
Step 4: Software – Arduino Libaries
WIFI: In order to connect to wireless networks, we need a library for ESP8266. If you do not have this before, go here https://github.com/esp8266/Arduino and follow the steps for adding it to Arduino IDE.
Display: The next library is for the seven segment display. Download the SevenSegmentTM1637 Arduino Library from https://github.com/bremme/arduino-tm1637 I tried several different libraries for the display. This one was the first I found that worked with my display board.
JSON: The last library is for handling JSON-data from Facebook. Download ArduinoJson - C++ JSON library for IoT from https://github.com/bblanchon/ArduinoJson
Facebook Fingerprint: To connect to Facebook we also needs a fingerprint. Instead of trying to explain this to you, I recommend taking a look at the documentation https://github.com/gbrault/esp8266-Arduino/blob/ma...
Step 5: Software – Code
Download the code here: https://www.hackster.io/code_files/114510/download
- BBB = Facebook App ID
- CCC = App Secret
- DDD = Fingerprint
Internet of Things Contest 2017
26 Comments
Question 1 year ago on Step 5
I think the host address is another than your code. Because my ESP 8266 can't connect with server.
Question 1 year ago
Does this still work? I can't get it working. maybe tips?
2 years ago
I love this project and can't wait to build it, still waiting on the pieces. Could someone help me change the code to work with a MAX7219 LED Matrix? I plan on using this library https://github.com/MajicDesigns/MD_MAX72XX
Thank you for any help!
3 years ago
Hi Sjsd...
i getting this problem
after uploading the code.....the output is
Connecting ....
Connected, IP address: 192.168.0.21
connection failed
connection failed
connection failed
The host address "graph.facebook.com" is correct?
Reply 3 years ago
Looks like the connection fails at wifi. If Facebook has changed the host address, you will get the correct one when you create the APP.
4 years ago
Hi All, here the code that work for me, very small changes I figured for sleeping late in the last 2 days (I have no skill in coding at all, so just trial here and there comparing the code I got from the examples). I add blinking every refresh to verify it does pulling new number if any.
One question though I love to get answered. There is about 15 seconds delay on the code (my setup) to push the new value from the facebook like number. How to make it updated every 1 seconds instead 'this 15 seconds'?
I am choosing "NodeMCU 1.0 (ESP12E)" for the board.
#include <ESP8266WiFi.h>
#include <WiFiClientSecure.h>
#include "SevenSegmentTM1637.h"
#include <ArduinoJson.h>
#define LED_BUILTIN 2
// Wifi
const char* ssid = "JohnDoe";
const char* password = "JD1234567890";
// Facebook
// https://github.com/gbrault/esp8266-Arduino/blob/m...
const char* host = "graph.facebook.com";
const String url = "/johndoe?access_token=xxxxxxxxxxxxxxx|yyyyyyyyyyyyyyyyyyy&fields=fan_count";
const int httpsPort = 443;
const char* fingerprint = "xxxxxxxxxxxxxyyyyyyyyyyyyyyyzzzzzzzzzzzzzz";
// Display https://github.com/bremme/arduino-tm1637
const byte PIN_CLK = D3; // define CLK pin (any digital pin)
const byte PIN_DIO = D4; // define DIO pin (any digital pin)
String payload;
SevenSegmentTM1637 display(PIN_CLK, PIN_DIO);
void setup() {
Serial.begin(115200);
delay(100);
// Wifi
Serial.println();
Serial.println();
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.print("");
Serial.println("WiFi connected");
Serial.print("IP address: ");
Serial.println(WiFi.localIP());
Serial.print("Netmask: ");
Serial.println(WiFi.subnetMask());
Serial.print("Gateway: ");
Serial.println(WiFi.gatewayIP());
// Display
display.begin(); // initializes the display
display.setBacklight(100); // set the brightness to 100 %
display.print("FACE");
display.blink();
delay(500);
display.clear();
display.print("BOOK");
display.blink();
delay(500);
display.clear();
display.print("PAGE");
display.blink();
delay(500);
display.clear();
display.print("LIKE");
display.blink();
delay(500);
display.clear();
display.print("0000");
display.blink();
void loop() {
String wifistatus = "WIFI OK";
// Use WiFiClientSecure class to create TLS connection
WiFiClientSecure client;
const int httpPort = 80;
if (!client.connect(host, httpsPort)) {
String wifistatus = "WIFI FAIL";
Serial.println("connection failed");
return;
client.print(String("GET ") + url + " HTTP/1.1\r\n" +
"Host: " + host + "\r\n" +
"User-Agent: BuildFailureDetectorESP8266\r\n" +
"Connection: close\r\n\r\n");
Serial.println("request sent");
while (client.connected()) {
String line = client.readStringUntil('\n');
if (line == "\r") {
Serial.println("headers received");
break;
// JSON
DynamicJsonBuffer jsonBuffer;
JsonObject& root = jsonBuffer.parseObject(line);
int fancount = root[String("fan_count")];
if (fancount > 0) {
Serial.print("Fans: ");
Serial.println(fancount);
display.clear();
display.print(fancount);
display.blink();
delay(500);
} else {
display.clear();
display.print("ERR1");
display.blink();
Reply 3 years ago
I’m also getting a delay with using your modified code, but mine is approx 30 seconds from the like count changing on Facebook to the counter screen updating. Did you ever figure out what’s causing the delay? I can’t see anywhere it would be in the code.
Reply 4 years ago
In my original code, I have a delay at line 80. https://www.hackster.io/helge-johnsen/facebook-fan...
I can't see it in your code. So I'm not sure where the 15 seconds delay comes from.
Reply 4 years ago
Or did I missunderstand your quiestion? The 15 seconds from startup to the first number displays. It takes some time for the board to connect to wifi and then to Facebook.
Question 3 years ago
Im trying to build this but there seems like there are further restrictions on how to retrieve the fan count now. Have you ran in to this issue with your existing counter?
Answer 3 years ago
Hi,
Did you manage success on this project? I'm also trying to use this tutorial but my doesnt connect to facebook. I'm not sure even that my app token is set correctly. Could you share your code and some details how did it work? Thansk mate!
4 years ago
I keep having certificate does not match yet my headers are receives and my serial monitor won;t indicate the fan_count at all, pls help me :(
4 years ago
I keep having certificate does not match and my serial monitor wont indicate the fan_count at all, pls help me :(
4 years ago
Would love to get this working but am having issue where i compile and get this...
exit status 1
'd3' was not declared in this scope
I have changed D3 and D4 to simply 3 and 4 to check if that might be it and that compiles and uploads fine but i dont think that correct. but no matter what i do it just tells me the pin was not declared in the code.
Also, does it matter what board you select in the Ardiuno program... (tools -> board). Should it be generic ESP8266 Module or maybe NodeMCU 0.9 or the 1.0?
Would really like to get this running!
Reply 4 years ago
Depending on what type of board you have you should select the board that fits in Arduion IDE. There are several types and you might have to download a libary for your type of board.
Depending what works for your board you can define the pins in different way. Try some of the examples from the display libary to check if it works: https://github.com/bremme/arduino-tm1637/tree/master/examples
Reply 4 years ago
I have the exact same boards and display as you have listed. I did get this running, but gives ERR1 now everytime it connects. Im guessing my access token needs to be renewed every hour? Is there a way of getting an access token that has no expiry?
Reply 4 years ago
To be honest, I have never received the ERR1 message myself. The reason for ERR1 is that fancount is not greater than 0. That is, it is 0 or less. It may also be that fancount is not a number. A little bad code, because this should have been checked in advance.
Try a Serial.println(fancount); Between lines 69 and 70. Is there a number or something else?
I have never renewed my access token. My display has run without errors since May. There may be a problem with your Facebook APP or settings.
Reply 4 years ago
Seem to be getting "certificate doesn't match" on every try.
4 years ago
idk how to obtain fingerprint
Reply 4 years ago
