Introduction: Fake Arm for IV Insertion and Venipuncture Practice
Here's a way to make a cheap, but effective, fake arm for practicing IV insertion or other venipuncture practice. Perfect for nursing school or practicing phlebotomy.
Glue gun/hot glue
Pool noodle
Thick waterproof tape = https://a.co/89Fwvgi
Latex tubing = https://a.co/fHZDaIV
Red food dye
Syringe with needle
22G IV catheter
Primary IV tubing
IV fluids
Step 1: Set Up the Arm
Measure and cut both your pool noodle, and your latex tubing.
You will want the tubing to be about 1 inch longer on either side of the noodle.
Step 2: Set Up for the Vein
Draw the shape of the vein you want to practice, then create a channel using scissors, knife, or soldering iron.
Step 3: Insert the Vein
Hot glue the tubing into the channel.
Step 4: Make the Skin
Cover the tubing with the tape.
This is your "vein"
Step 5: Set Up for the Connecting Part
Take your 22G catheter (I'm using a practice catheter, but any will do)
Separate it (You won't need the entire thing)
Use just the actual catheter itself (The part that would stay in the patient)
Step 6: Add the Connecting Part
Insert the catheter into one end of the tubing.
This completes your "arm"
Step 7: Set Up the Blood
Take your food dye, syringe with needle, and IVF (I used 1L NS, but it could be anything)
Draw up some red food dye into your syringe (It doesn't take a lot. Less than 2 mL is fine)
Insert the food dye into the left-side port on the bag (This completes your "blood")
Step 8: Get the Blood Running
Spike your bag with the primary tubing
Connect the other end to the catheter on the arm and prime
*Notes: the free-flowing fluid will make a mess if you don't have something underneath to catch it
Step 9: Practice
Practice!
You can now stick your fake arm.
To get a flash, make sure you have a good amount of pressure pushing the fluid through. You can accomplish this by making sure your bag is up high or putting pressure on the bag with something (like a pressure bag or even a BP cuff).
Step 10: Optional
  • In step 6, you can add a drop of super glue onto the catheter to make sure it stays long-term.
  • Take the clamp from a J-Loop and clamp the opposite end of the vein from the bag.
  • Collect the fluid that pours out from the vein, you can redraw it and reinject it into the bag to help it last longer.
