Introduction: Fall Faux Window Design Using Picture Frames From Dollar Tree
Hello everyone! I was recently inspired to create my latest craft on a rainy day. It rained most of the day, and I had time to go through and clear out a few things in my craft room. I came across four wood picture frames I had recently purchased at my local Dollar Tree. I decided I would create a faux fall window design. I hope you enjoy this craft just as much as I did!
Four picture frames--I'm using picture frames I purchased from Dollar Tree. Size-3½ inches by 5 inches.
Hot glue- You will also need a heavy-duty adhesive like E6000 or gorilla glue.
Fall leaf stickers--I purchased my pack at Dollar Tree
Paint- I'm using a color called Milk jug for my frames, red for my wood letter sign, and brown to add a few streaks on the frame
One wood fall letter sign--Purchased a pack at Dollar Tree
Paintbrush
Twine
Scissors
Optional--Fall craft leaves
Screwdriver--You will only need this if you purchased this particular picture frame with the metal design on the bottom
Step 1: Removing the Decoration Off of Frames
Start by removing any decorations on your four frames. I used my screwdriver to remove the screws, and metal design. Skip this step if your frames are plain and without the decorations.
Step 2: Removing Glass and Backing of Frames
Next, remove the backing from all four frames. Once you have removed the backing and glass. Set your glass aside.
Step 3: Applying Paint to Frames
Once the backing and glass have been removed, take your paint brush and begin to apply your paint. I applied around two coats of paint and in between coats I used my blow dryer to dry my paint.
After you have applied paint to the front of each frame, take each frame and begin to paint all areas that will be visible once the frames are glued together.
Step 4: Applying Your Brown Paint
Take your brown paint and use a paintbrush to gently add on a few streaks. I wanted to give my frames a little bit of a distressed look. I used my paintbrush and randomly added a few streaks of my brown paint. I used my finger to gently spread the paint.
Step 5: Attaching Your Frames Together
Next, begin to add your frames together. I used hot glue to connect my frames, but shortly after I noticed that it would take more than just hot glue to attach my frames. I grabbed my E6000 glue and added that along with my hot glue. This will help to keep your frames together and prevent them from coming apart. I definitely recommend using a second adhesive along with your hot glue.
Step 6: Adding Paint Onto Your Wood Fall Sign
After, take your wooden sign and begin to add paint to it. I decided to go with a red paint color. Next, take your wood sign and glue it onto the middle of your four frames.
Step 7: Adding Your Glass Back Into Your Frames
After, turn your glued frames over and begin to add only your glass back into each frame. I found that it helps to add hot glue into the four corners of each frame before adding in your glass. Doing this, it helps to keep your glass in place and prevent it from shifting.
Step 8: Adding Your Stickers and Twine
Take your fall stickers, and begin to add them to your glass. I decided to add my stickers to the front of my glass. You can always add your stickers behind your glass. Keep in mind that by adding your stickers behind the glass you would need to add adhesive in order to keep them on your glass. This is why I decided to stick with adding my stickers to the front of my glass.
You are now ready to add your twine onto the back of your frame design. Flip your frame over, and cut a medium-length section. Next, bend back the flexible points on your frames. I added hot glue, and then tied a knot around each point. The flexible points are the tabs that hold in the glass.
I went ahead and also added the remaining twine down onto my frame using my hot glue. You can also add an extra adhesive when attaching your twine.
Step 9: Adding Craft Fall Leaves -optional
This last step is completely optional, but I decided to take a few fall craft leaves and add them to my frame. I thought it was a simple addition and it turned out so cute!
For more crafts and DIY projects visit--https://stephcreatesthingsdiyhomeandcrafts.blogspot.com/
Video tutorial--https://youtu.be/P0WieJgt2O0
