Introduction: False Ceiling
To build the false ceiling I have used the following materials:
Quarter inch plywood sheets and 1"x1" wood bars
Screws and nails
wood glue
wood filler
sealer and paints
led strip
ceiling led lights
sanding paper
Tools used:
circular saw
jig saw
drill
Step 1: Adding the Frame
The first task was to add a frame to give my thoughts a shape :)
Step 2: Covering the Frames With Plywood
Then, I started covering the frames with the plywood sheets. This was the hardest part as I was working alone and every now and then had to call for someone to hold the sheets for me. Fortunately I also had some clamps laying around (These are always my best assistant while working with wood.).
Step 3: Testing the Led Strips
Now that everything was in place, I filled all imperfections with some wood filler and sanded everything. After that I tested the led strip I had bought from Ebay. This is a 5 meter RGB 5050 led strip that came with a power supply and remote.
Step 4: Painting and Adding the Led Ceiling Lights
Now, it was time to seal and paint everything. I have drilled holes for the ceiling leds using a hole saw and the added the lights.
Hope this instructable is of any use to you.
Thank you.
You might also like my other projects whose link are below:-
A frozen castle themed bed with slide, lift, periscope, play kitchen and many more features: https://www.instructables.com/id/Castle-Themed-Bunk...
A mutipurpose table and chair for kids with an electric keyboard piano, clock, mirror: https://www.instructables.com/id/Multifunctional-T...
Light pendant from recycled wine bottles
https://www.instructables.com/id/Light-Pendant-From...
Wall-With-Built-in-Shelves
https://www.instructables.com/id/Wall-With-Built-in-Shelves/
And thanks for voting if you like them. ;)
