Introduction: Famous LM35 With Mediatek Linkit One Board
In this Instructable you will be able to Interface famous Lm35 with Mediatek LinkitOne Board.
The LM35 series are precision integrated-circuit
1• Calibrated Directly in Celsius (Centigrade) temperature devices with an output voltage linearly- • Linear + 10-mV/°C Scale Factor proportional to the Centigrade temperature. The • 0.5°C Ensured Accuracy (at 25°C) LM35 device has an advantage over linear • Rated for Full −55°C to 150°C Range temperature sensors calibrated in Kelvin, as the user is not required to subtract a large constant voltage • Suitable for Remote Applications from the output to obtain convenient Centigrade • Low-Cost Due to Wafer-Level Trimming scaling.
Step 1: Requirements
- LM35 Temp Sensor
- Linkit One Board
- Connecting wires
- Usb cable
Step 2: Connections
Vcc : 3V3 on Board
Out: A0 on Board
GND :Ground
Step 3: Code,compile and Run
Upload The Code And You are Ready To go!!!!! Congratulations You have successfully interfaced LM35 with the Famous Mediatek Linkit One Board.
Have Fun!!!!!
