Introduction: Fan Hat
I made this hat so I could cool off on sunny days it works very well but is also pretty dangerous considering it is so close to your eyes.
Step 1: Battery Pack
The hat is powers by two AAA batteries
Step 2: Motor
I used a small motor from a sewing machine Then got some spare plastic andante a small propeller
Step 3: Base
The base is the thing that holds the Battery pack the motor and the switch I took some aluminum and bent it in this shape ________ \ ___/ Then drilled a hole in the top, glued the switch in then used double sided tape to tape the battery pack to the top then I used zip ties to connect the motor to the bottom
Step 4: Connection
I took the wires from the battery pack ran one through the switch then connected it to the motor the other one just connected to the motor
Step 5: Attaching Base
I connected the base using rivets
