Introduction: FastlED NeoPixels Strip and LED Ring Projects Arduino 2021
NeoPixels and FastLEDs are a great way of creating beautiful projects for various applications. It can be a frame for a great table or a roof. Beautiful rings or some decor as well.
NeoPixel LEDs and FastLEDs are addressable LEDs which have made the hardware setup very simple and sound. FastLEDs have only three connections
Power supply
Data line
Ground
The Power supply supplies 5 V or 12 V depending on the parts. In simple terms, the Arduino will send out the values of RGB for each LEDs serially over one line. If there are 2 LEDs, the Arduino will send the data of first LED (RGB) and then sends the data of the second LED (RGB). For a series of connected n LEDs, the data would like something like this: R1G1B1-R2G2B2-R3G3B3-......RnGnBn
Once this data passes through the first LED, the output from the first LED to the second LED looks like this: R2G2B2-R3G3B3-....RnGnBn
The same thing happens with every LED in series and the final LED will only receive RnGnBn. Let us now have a look at wokwi Arduino simulator to simulate NeoPixels and FastLEDs Quick link for an example: https://wokwi.com/arduino/libraries/FastLED
Step 1: Let Us Begin "Hello World": on Wokwi Arduino Simulator
FastLED and Wokwi Arduino project 1: Blink
Project link on wokwi Arduino simulator: https://wokwi.com/arduino/libraries/FastLED/Blink
snapshots:
FastLED blink example - snapshot from wokwi Arduino simulation
The blink example should be equivalent to hello world example in the C program. Only the point to be taken care is the right pin number of Arduino. Which acts like a data pin (Pin number 3 in this example). by easily modifying the code, you can make the colour to blink Green or Blue. Can you try? you can start from here.
Step 2: The One-dimensional Array - "ColorPalette": - Wokwi Arduino Simulator
The one-dimensional array - "ColorPalette":
FastLED and Wokwi Arduino project 2: ColorPalette Project link: https://wokwi.com/arduino/libraries/FastLED/Color...
snapshots:
ColorPalette example on Wokwi Arduino Simulator
Colorpalette is the Hello world of FastLED family. This beautiful code creates a mesmerising view. You can easily change the number of LEDs as well as the Arduino DataPin to which the LED is connected. Also, take care of the power wattage of the LEDs. Arduino will not be able to supply huge currents. It is always advised to use separate 5 V adapter for the LED power supply. Make sure to keep the ground of the 5 V power supply and ground of the Arduino Common. Vary the delay or number of LEDs, get creative and create your own version of this project here.
Step 3: 2D FastLED Matrix - "Cylon":- Wokwi Arduino Simulator
Let us see 2D FastLED matrix - "Cylon":
FastLED and Wokwi Arduino project 3: "Cylon" Project link on wokwi Arduino simulator: https://wokwi.com/arduino/libraries/FastLED/Cylon
snapshots:
Cylon FastLED project on Wokwi Arduino Simulator
Cylon is a first example of the 2D matrix on Wokwi Arduino simulator. It brings the user the ability to display complex patterns and also interesting GIFs and notice board style projects. To edit the size of the matrix, head to the diagram.json file in the project. The number of LEDs will be equal to the product of the number of rows and number of columns in the panel. Can you make it to display a moving dot?
Step 4: Digital Rain FastLED Project on Wokwi Arduino Simulator
FastLED and Wokwi Arduino project 4: "DigitalRain"
Project link on wokwi Arduino simulator: https://wokwi.com/arduino/libraries/FastLED/Digit...
snapshots:
DigitalRain Arduino simulation on Wokwi Arduino simulator
For this project and all others, the original author information is retained in the code. Please feel free to play with the simulation and create your own version of digital rain!
Step 5: Fire2012 FastLED Project on Wokwi Arduino Simulator
Fire2012 FastLED project on Wokwi Arduino simulator:
FastLED and Wokwi Arduino project 5: "Fire2012" Project link on wokwi Arduino simulator: https://wokwi.com/arduino/libraries/FastLED/Fire2...
Fire2012 FastLED simulation on wokwi Arduino simulator
Step 6: ​LED Face FastLED Project on Wokwi Arduino Simulator
LED Face FastLED project on Wokwi Arduino simulator:
FastLED and Wokwi Arduino project 6: "LEDFace" Project link on wokwi Arduino simulator: https://wokwi.com/arduino/libraries/FastLED/LEDFa...
snapshot:
LEDFace FastLED project on Wokwi Arduino Simulator
Can you try to make emojis?
Step 7: MetaBalls FastLED Project on Wokwi Arduino Simulator
FastLED and Wokwi Arduino project 7: "MetaBalls"
Project link on wokwi Arduino simulator: https://wokwi.com/arduino/libraries/FastLED/Metab...
snapshot:
Metaballs - FastLED project on Wokwi Arduino simulator
Step 8: ​XY Matrix FastLED Project on Wokwi Arduino Simulator
XY Matrix FastLED project on Wokwi Arduino simulator:
FastLED and Wokwi Arduino project 8: "XYMatrix" Project link on wokwi Arduino simulator: https://wokwi.com/arduino/libraries/FastLED/XYMat...
Step 9: Join Wokwi Now and Engage in Interesting Projects and Contributions 😃
