Introduction: Faux Gilded Mirror
I always have a hard time throwing anything away. Especially my grandson's little toys that he has outgrown. I found a fun and creative way to continue to "play" with those old toys.
12"X12" mirror tile (home depot)
20"X20" plywood
(2) 20"X20" cardboard
Elmers glue
Elmers Wood Glue
Gold Spray Paint
pencil
ruler
Exacto blade
screwdriver
Picture hooks and wire.
A Lot of old plastic toys (also jewelry)
Step 1: Prepare the Frame Base
Using 20"X20" cardboard cut the 12"X12" section from the middle of each cardboard. Measure a 4" border.
Use Elmers to glue the cardboard pieces together which will make the base quite sturdy.
Step 2: Gluing
Using a sufficient amount of Elmer's glue pile on the pieces to decorate the frame. Only use hard items on the frame. Anything with movement won't let the spray paint adhere. I cut the string off that little creature and I never use anything with fur or hair (like a troll or my little pony )
Let the glue dry thoroughly (this can take several days)
Step 3: Prepare the Hanger
While the glue is drying attach the frame hooks and wire to the back of the plywood base. This mirror is going to be very heavy so be sure to create a strong hanger.
Step 4: Glue Mirror Tile
Mark and glue the Mirror tile to the center of the plywood base. I used Elmer's Wood Glue
Step 5: Spray the Frame
When the frame is completely dry (and remember this can take several days) Spray the frame to create the "gilded "look.
Step 6: Final Step
When the spray paint dries spread Elmer's Wood Glue around the entire outside area of the plywood surrounding the mirror. Place the gilded frame on the base and again, give it time to dry.
