Faux Marquetry Backsplash
6,941
110
21
Introduction: Faux Marquetry Backsplash
About: Currently renovating a 100yo house.
How To Make A Faux Marquetry Backsplash
An alternative to tile, especially if you love the warmth of wood.
What you will need:
An MDF board at least 6mm thick the size and shape of your backsplash, plus a perimeter the width of the melamine ( 1.7cm for me)
Access to a lasercutter-- many universities offer public access
A program or combination of programs that lets you design to the millimeter and pump out vectors
Veneer mounted on a softwood
Plastic gloves
Stains, dyes, polyurethane
Rags
Paintbrushes
Sandpaper from 80# to #320
Dremel with sanding heads
Wood glue
Clamps
Melamine
Screws
Caulk
Release agent
Epoxy resin
Step 1: Measure Space
Measure out the space for your backsplash, noting where each stain line of your cabinetry falls if you’ve done crazy cabinet staining. Don't forget to include data like lightswitches or outlets.
Step 2: Draw the Plan
Open a new doc on a vector-friendly program, hopefully moreso than Sketch-Up. Set the file in millimeters or inches so you can build a scale 2D model on your screen. Set your line width to be a big broader than default width on Sketchup, so go from 0.5pts to 0.7pts. (Now even if the wood is a little warped, the pieces will still fit together.) Transfer your data points, and design away. Think about how you can use grain orientation, eg horizontal for water, vertical for tree trunks. Make sure everything has a color even if it isn't your final color.
Step 3: Research Lasercutter and Lumber
Research your lasercutter. How thick a piece of wood can your local lasercut cut? Many laser cutters can't cut more than 6mm-thick pieces of veneer-on-a-softwood. Also learn how big a sheet of wood your local laser cutter can handle. My local university's Fablab handles a max of 60cm x 30cm, so I farmed out the longer pieces to a firm with a bigger machine.
Research lumber. What wood is available? I had to hunt around just to come up with oak and walnut veneers on pine. Some US lumberyards have dozens of species to choose from, already in veneer-on-softwood form. Some lucky humans can even choose figures in the wood to incorporate into your design.
Step 4: Lasercutting Your Drawing
Make your sketchup or other drawing into a jigsaw puzzle with no one piece exceeding your lasercutter limits. Avoid straight lines.
Above your drawing, create blank 2D forms the maximum size of the laser cutter bed for each species of wood and each orientation of wood grain. Now copy and paste the center, not the outlines, of all puzzle pieces onto the correct board and orientation. You know you are done when there is no more color in the design.
Import the panels into Inkscape, save as .svg files. Go lasercut them.
Step 5: Dryfit Your Pieces
Dryfit the pieces together on a level MDF board the size of your future backsplash plus a perimeter of melamine.
Step 6: Dye/ Stain
Take it apart and dye/stain all like-colors at the same time to reduce variation. Nota bene that veneer can only hold so much aniline dye before the glue under it starts reacting, which is why you can see some odd green under the blue "water" dye. Once you are happy enough with the aniline dye, give it a coat of polyurethane so the dye stops coloring everything if you just look at it funny. I also realized that my oak and walnut were never going to stain like the ash cabinets, so I started changing the design to try to delineate different redwood hues. Better to match cabinets and veneer if possible.
Step 7: Create Form for Epoxy Pour
Think about how thick you want your epoxy resin to be. Epoxy resin is not that cheap. Add the thickness of your veneer pieces, the MDF and however thick you want your epoxy, plus 5mm for enthusiastic epoxy spreading and that's the height of your melamine fence. Rip that melamine to create the perimeter, screw the strips in. Now you should have the exact dimensions of your backsplash inside the perimeter. Caulk the inside perimeter edge very lightly. Paint the bottom a color you won't mind showing through if it happens. Rub/spray the melamine with a release agent. If you will have outlets, use a knock-out form for them. I didn’t, and afterward had to saw a slot for a light switch, causing an unsightly gap between resin and wood.
Step 8: Do the Puzzle
Starting from the top down, glue the pieces in. I used weights on scrap wood as clamps. There's a better way, I am sure.
If you wind up with gaps, use the dremel to whittle some veneer-on-softwood to fill them, stain/dye, glue and weight it in there, and you're back in business. If the veneer pops off the softwood, you can still shape it-- just be sure to put painter's tape on both sides to support it.
Step 9: Prep to Pour Epoxy
Paint entire completed puzzle with polyurethane. I switched from matte to satin at this stage. You can go in that direction, but not the reverse.
Step 10: Pour Countertop/Hard Epoxy Resin on Wood So It Lasts As Backsplash
Pour epoxy resin per manufacturer's instructions. I used Resion Giethars, a Dutch product for countertops. Let it cure. Demold. Cut off excess MDF.
Step 11: Hang It
Screw it on the studs in your wall. Or glue it on, using supports until dry.
I wish I had had more species of wood and had stained the rocks less, but you know what they say about hindsight.
I hope to sell one, one day. In the meantime, I’m sure other people should just go for it and make their own. If you do, it’d be great to see what you make!
Be the First to Share
    • Make It Bridge
      Make It Bridge
    • Game Design: Student Design Challenge
    • For the Home Contest
    21 Comments
    msdusa
    msdusa
    3 years ago
    Nice cabinets.
    alikayn
    alikayn
    3 years ago on Step 11
    It's fascinating. Do I perceive a bit of Japanese influence? Similar effect could be done using fine outlines and faux wood, faux marble, even faux stained glass. I made a chessboard in that way.
    jenmarya
    jenmarya
    Reply 3 years ago
    Your chessboard sounds lovely. Yes, some Japanese influence. I don’t see why an alternate method wouldn’t produce similar results. I just have an abiding thing for real woodgrain, the depth, luster and glow.
    scole456
    scole456
    Question 3 years ago on Step 11
    Stunning! Are your cabinets painted? Or did you marquetry them, too? You say your frame failed. What did you do wrong? or do right the second time? Did you have epoxy all over the floor? How do you clean up that kind of mess? Do you have a workshop area, like in the garage?, or did you do this in the kitchen? How did you find out about being able to do this at college/university? Was this your first big attempt? I really like those cabinet doors. What was your inspiration for this whole thing? What's wrong with the rocks? They look good to me. Questions, questions. Are you planning your next project, yet?
    jenmarya
    jenmarya
    Answer 3 years ago
    Epoxy waterfalls— My caulk lines in the form were initially too thick to allow placement of the puzzle. I then scraped them too thin to get the pieces in there, ergo holes and waterfalls. The epoxy came off the concrete floor pretty easily— a huge relief. My daughter now has a great story re watching her mom be comically frantic, getting epoxy resin on shoes, clothes, glasses, bystanders....
    jenmarya
    jenmarya
    Answer 3 years ago
    Hi! The cabinets are sanded and stained Ikea Torhamn (ash wood) cabinets. I love wood, but not if it just looks like a stack of firewood, so it was always planned to change them and I love ombre. So I embarked on that sanding/ staining project in the partially renovated kitchen, where the backsplash was also completed, while living there— that part was not so fun. Here are photos of the process.
    After the cabinets were done, I couldn’t find tile that didn’t fight with them. I had already made a lasercut radiator cover (mockup in photo) and saw people were starting to lasercut hard wood. I thought I’d do an interesting pattern that used ombre staining and joined the cabinetry lines.
    I tried using a vinegar- rusty nail mix to stain the rocks. I couldn’t layer the color like I did with the other stain. Found that frustrating and wound up with what look to me like dirty rocks. Would have like to use a grey aniline dye I could have built up.
    Last, I live in a college town so am keen to take advantage of tools that are free to the public. Just about everyone has access to a FabLab if they call their local university!
    The current project is a kitchen island/ circular banquette I designed. Trying to sort out the upholstery and pour concrete at the moment.
    Thanks very much for your interest! I like questions. Ask more if you want. :)
    3B7DF3A5-DAE5-4BFD-A678-35DFA95A469A.jpeg945212AE-2171-41FF-BB6B-18F3C6646411.jpegD5F20A38-2658-42BA-ACE9-8DC0A4F26D64.jpeg
    Bloodbeard
    Bloodbeard
    3 years ago
    Wow... incredible. Please do my house!
    jenmarya
    jenmarya
    Reply 3 years ago
    Thanks for that. I would be honored. :)
    BrandonP43
    BrandonP43
    3 years ago
    This is beautiful! Amazing work!
    jenmarya
    jenmarya
    Reply 3 years ago
    Appreciate your kind words very much.
    pdavis19
    pdavis19
    3 years ago
    Totally agree. Gorgeous work. Really creative and impressive.
    jenmarya
    jenmarya
    Reply 3 years ago
    Thank you very much.
    MattM370
    MattM370
    3 years ago
    wow!
    how long did it take you to do that?
    jenmarya
    jenmarya
    Reply 3 years ago
    Way too long? It was a back-burner project for 4 months, R&D all the way. No one here had heard of veneer-on-pine or aniline dye. The plan to lasercut Corian for the rocks had to be considered and discarded. Glueing in the pieces had to be redone in some instances—did not have enough clamps. Also, had to try twice to pour the epoxy— the form failed the first time. Mistakes were definitely made. :) The next one should be much faster.
    GeneSmith
    GeneSmith
    3 years ago
    Totally amazing! Thanks for the detailed instructable.
    jenmarya
    jenmarya
    Reply 3 years ago
    Thank you.
    lleegilmer
    lleegilmer
    WOW! Stunning but I'd never have the patience.
    jenmarya
    jenmarya
    Reply 3 years ago
    Thanks, there were times when I had little left.
    jessyratfink
    jessyratfink
    3 years ago
    Dang that is stunning! I've never seen a backsplash like this before :)
