Introduction: Faux Succulent Rock Garden
Today I will take you through a few steps to create your faux succulent rock garden using one five-dollar wood display box. I found this wood display box at my local Target last year and I honestly wasn't sure what I was going to create. I stashed it away for a few months and I finally decided to create a succulent rock garden. I'm using materials I had from previous crafts. I'll walk you through each step and provide you with a material list.
Materials
One wood display box- Purchased at Target in the dollar spot. The box has plastic panels, not glass. The top of the box has a sliding plastic panel so that you can easily remove it and add items.
Peel and stick tile decal or any decal of your choice
Paintbrush
Faux succulents
River pebbles-I purchased these at my local Dollar Tree
Paint-I am using black paint
Optional-lighted leaf garland
Scissors
Pencil or marker for tracing
Hot glue
Craft knife-optional
Be sure to check out the video tutorial
Step 1: Applying Paint to Your Wood Box
Begin by using your paintbrush to apply your paint to your wood box. I used a thinner paint brush to get into spaces around the clear plastic areas. I painted all wood surfaces. You can leave the side you add your decal unpainted.
Step 2: Tracing Out Your Wood Box Onto Your Decal and Cutting It Out
Next, lay your wood box onto your peel-and-stick paper and begin to trace it using your pencil or marker. I found that using a black marker was easier to see exactly where my marks were at. Once you have traced out your wood box, use your scissors and cut out your traced shape.
Step 3: Attaching Your Decal to Your Wood Box
You are now ready to add your decal to your wood box. I decided to use hot glue, but you can use any adhesive. I glued the decal onto the outer surface of the box since it would have been too tricky trying to fit it inside the box. If you notice that you have extra on the sides after attaching it, take your craft knife and carefully remove any of the extra decals.
Step 4: Adding in Your Rocks
After, take your river pebbles or any smaller rocks and begin to add them inside your wood box. Just add enough of your river pebbles to cover the bottom of your display box.
Step 5: Adding Faux Succulents
Take your faux succulents and start to add them to the pebbles. I had my succulents from previous crafts. The sizes range from small to large.
