Introduction: Feel Like a Sir Ninja
**If there are spelling errors, I'm sorry! I'm not totally fluent in English so I'm using a translation tool as an aid for making this Instructable.**
I always imagined myself as an old man and how would i protect myself. So I thought, why not a bengal with a blade?
This Instructable is the step by step how I did it.
Step 1: Materials / Tools
So, the materials i used here,i have all at my home and the wood, I used construction wood.
Materials:
-Blade iron: 70cm
-Wood pieces:
- 80cm x 2cm x 4cm
- 10cm x 2cm x 4cm
- 15cm x 5cm x 4cm
- Wood glue.
- Varnish.
- Nail
Tools:
- Set-square
- Chisel
- Hacksaw
- Pencil and rubber
- Sandpaper
- Drill-(1" and 1/3 ")
- Planer-manual
- Soldering iron
- Hammer (Rubber and Iron)
- Brush
- Metric trena
- Screwdriver
- Whetstone
- Staples-wood
- Goggles
- Morça
- Circular saw
- Drilling machine
- Emery
- Hacksaw
Materials:
-Blade iron: 70cm
-Wood pieces:
- 80cm x 2cm x 4cm
- 10cm x 2cm x 4cm
- 15cm x 5cm x 4cm
- Wood glue.
- Varnish.
- Nail
Tools:
- Set-square
- Chisel
- Hacksaw
- Pencil and rubber
- Sandpaper
- Planer-manual
- Soldering iron
- Brush
- Metric trena
- Screwdriver
- Whetstone
- Staples-wood
- Goggles
- Morça
- Circular saw
- Drilling machine
- Emery
- Hacksaw
Step 2: Preparation Hood
I chalked the ends to get the alignment parts after.
I chalked with a pencil on the inner part where the blade will be from at 10cm base, so that the blade was not until the end. I scored the risk with the big chisel and with the chisel slightly larger than the blade i cut the part that she'll stay.
After doing this in two parts and sanded I glued with the wood glue. I held the two parts with the help of clips and let dry for a night.
Step 3: After a Night
After the glue has dried, I scored the measures to cut the base of the walking stick, after ... I removed the excess with Planer-manual and sanded.
Step 4: Preparing the Blade
I marked the right size and cut of the blade, nailing it to the handle of the walking stick, 8 cm long, with Durepoxi (A type of sugru).
Step 5: The Handle
Using a piece of wood 10cm x 2cm x 4cm, I stuck and molded and I glued it on the cable using Durepoxi.
Step 6: The Union
After sharpening the blade, I made the piece that holds the cable to the base of the walking stick using the same method as the other pieces.
Step 7: The Gran Finale
I drew in the piece using a pencil and then carve using a soldering iron to burn the wood. After the ready drawings I passed varnish.
I used the iron rings to keep the base together.
