Felt IPhone Envelope
Intro: Felt IPhone Envelope
I think this is a pretty simple project and a lot of fun. No sewing machine required. You just need to know a basic blanket stitch.
STEP 1: Cut Panels
I cut two panels of felt at 9 x 3.5 each. I chose camel and gray. Camel is a hot color this fall!
STEP 2: Create Your Flowers
For the flowers, I freehand in marker and cut inside the marked area with a scissor. You could also just flip over your felt so there are no ink marks.
This is where you can have fun. Flowers can have as little as 3 petals to several, so you can't really make a mistake.
STEP 3:
I split a 6 strand piece of embrodery thread into 3 strands. I like to use several colors to mix it up a bit.
STEP 4:
I pin the flowers to the felt and use a blanket stitch to sew to panel. Be aware of how your "envelope" is going to fold, so your flowers are positioned where you like them. I like to layer a few flowers on top of each other. I also set them a bit askew.
I used a Chenille Needle, size 18-22. This needle has a large eye...after all these years of crafting, I can't see anymore!! Well, just not as clearly, so the larger the needle, the better for my eyes.
STEP 5: Make Your Pocket
To make my pocket, I cut a slit with an exacto blade into one panel around 4.5 inches from the bottom (I guess that would be right in the middle of the panel) and about 1/4" from edge. This is where your phone will slip into, so make sure it's wide enough. Blanket stitch around the slit. Sometimes, I use all 6 strands of the thread for this part.
STEP 6: Pin and Sew
Now pin both of your panels together, with flowers facing the outside, and sew completely around with a blanket stitch.
Place your phone in the pocket and fold.
You could add some sort of enclosure - a button, velcro, snap, but I find, when it comes to a phone, I want to be able to get to it as soon as it rings and an enclosure just gets in the way.
Have fun...hope it FELT good!
12 Comments
Muhaiminah Faiz 11 years ago
Facci Designs 11 years ago
itisanniebelle 11 years ago
zach13811 12 years ago
Facci Designs 12 years ago
sheraphoenix 12 years ago
javajunkie1976 12 years ago
BarginsTech 13 years ago
just a question though, for step 5: youre only sewing the one side of the slit? and does the corners have to be done too? would the slit rip over time?
Thank you :D great Instructable!
Facci Designs 13 years ago
Hope this answered your question
