Introduction: Felted Wool Shoe Liner
Now that the cold weather has settled in I made a pair of felted wool shoe liners to keep my feet warm. I always have cold feet in the winter months. Wool is one of the best fabrics to wear when it is cold. Wool wicks the perspiration and keeps our feet dry. I wear open healed shoes and they are not very warm. These shoe liners helped keep my feet warm and comfortable. I will show you how to felt a wool sweater, make a pattern, and sew a liner for your shoes. Lets get started!
Step 1: Supplies
Please note: Your shoe size will determine how much fabric you will need. You will need 2 pieces of interfacing, lining, and felted sweater fabric for each pair of shoe liners. You must use laundry soap for felting the sweater. Simply add the soap as you would any other laundry load. I had plans for the printed fabric of this sweater but it would have given the shoes a cute appearance. You may sew these liners by hand and it would be fine. A machine is faster but these are so small it still would not take very long to sew.
- 1 Thin soft wool sweater
- Iron in interfacing
- Lining
- Needle
- Thread
- Sewing pins
- Scissors
- Paper
- Shoes to make pattern
- Marking pen
- Seam ripper
- Pattern
- Iron
- Ironing board
- Sewing Machine
- Laundry soap
- Washer
- Dryer
Step 2: Preparations for Felting
- Remove all the seams of the sweater
- Remove the cuffs
- Buttons
- Pockets
Step 3: Washing the Sweater
- Set washer for a long wash cycle
- Set temperature for hot wash and rinse
- Wash it
- Check to see if it is felted enough for you. If it is not enough then wash it again.
- Dry it on a hot heat cycle.
Step 4: Pattern
- I used a shoe insert to trace a pattern but you may trace your foot to make a pattern from.
- Trace the foot or shoe liner onto the paper.
- Cut the pattern out trimming 1/4 inch from your mark line to allow for the seam.
Step 5: Interfacing, Lining, and Felted Fabric Pieces
- Fold the felted sweater right sides together.
- Place the foot pattern on the top of the felted folded piece and pin it to the felted piece.
- Cut it out.
- Set it aside.
- You should have a right and left foot piece.
- Repeat the above method using the lining fabric.
- Repeat the above method using the interfacing.
Step 6: Ironing
- Iron the lining and felted pieces
- Place the interfacing on left and right foot piece of the (lining) with the textured side to the wrong side of the lining.
- Lay a piece of the lining over the 2 pieces and press according to the interfacing directions.
- This prevents your iron from getting sticky.
Step 7: Pinning
- Pin the felted foot pieces to the lining right sides together.
- Pin it in the way you like. I use this method because it works for me best.
Step 8: Sewing
- Begin sewing at the arch area and work all the way around leaving a 4 inch opening to turn the fabric right side out.
- Trim threads.
- Cut small slits up to the seam area all the way around the seam.
- Turn right side out.
- Using a pen work the seams smoothing the seam allowance.
- Press well.
- At the opening turn under 1/4in hem to match the seam.
- Top stitch all the way around the insert back stitching at the end.
- Press well.
Step 9: Place in the Shoe
- Place the insert into the shoe smoothing it as you slide it in.
- You may need to work it a little.
Step 10: Sunshiine's Final Thoughts
Try it on for size! Mine fit very nicely. I am making a few pairs of these. They can be machine washed when ever needed. Wash cold on delicate cycle. I would not put them in the dryer though. I was surprised how comfortable they were. I am going to try and make a pair of slippers out of a felted sweater. These would look so cute with a pretty sweater print. They would make good boot liners also. You could make them for rubber boots. I never did like rubber boots because they don't breathe but sometimes rubber boots are better for snow and rain. Please stay tuned because I have a lot of fun projects lined up.
Thank you for stopping by and have a safe and warm winter!
Sunshiine
29 Comments
11 years ago on Introduction
We haven't gotten much snow so far and because my feet don't get wet, I've found it very hard to give up my Crocs even though they get cold! I am going to try this. Thanks sunshine!
Reply 11 years ago on Introduction
Thanks for commenting! Crocs are fun! Have a beautiful day! Sunshiine
I don't have a dryer. Would washing in very hot water be good enough? I can go to a laundromat if not.
I would think it would shrink but how much would be the key. Can't hurt anything! Go for it. Thanks for commenting and please do have a terrific day! Sunshiine
I found a used wool blanket at a yard sale that worked well for making slippers. I just washed and dried it on HOT first to shrink and felt it. I probably have enough wool to make 20 pairs of slippers. I also made wool mittens out of the blanket and have lots left. Great tutorial. Thanks for posting!
12 years ago on Introduction
This reminds me of when my brother bought a pair of crocs that were lined with carpet!
Reply 12 years ago on Introduction
Hmmm now that is a thought! Thanks for the input! Have a nice day!
Sunshiine
currantly, I'm working on making a pair of slippers from some material I found....it's a fleece of some kind...
Awesome! Are you going to enter the warm challenge? Winners receive an awesome soft blanket. Have fun!
Sunshiine
not sure yet...but that very thought has crossed my mind....I could sure use the blanket that's for sure...
Sure hope you do! It is great fun! I will be checking!
sunshiine
12 years ago on Step 3
I am glad you did this. I took a class on felting wool, but they said to buy the wool online and it cost a fortune. I can get wool sweaters pretty cheap once they go on clearance and it would make so much more.
Ms.Blossom,
many times you can go to the Salvation Army or Good Will Stores & find things that nobody else wants for like dirt cheap...not just the usual stuff, but things like material, sewing supplies, craft supplies, etc.
I found an old stereo that did not work, bought it for $1 I think it was because I needed the electronic parts for a project I was working on...
It's amazing what one can find at these places.
The thrift store by me is pretty hit and miss. I do like to check there every so often but have better luck at yard sales. Yard sales are the best for cheap scrapbooking supplies and needlepoint supplies by me :)
I live in a small town and finding stuff is hard sometimes. I wanted to make an Instructable but can't get the supplies and they are a unique item. I could find it in a large city though. Don't order online. I need to set up a paypal account or something. It would make it easier. All crafting stuff can cost a lot so I use cans and bottles and whatever I can accumulate. It is more fun to create anyway. Have fun with the contest!
Sunshiine
Thanks for sharing Sirjames! I enjoy the find when I go there. Have a great evening! Sunshiine
I could not find any wool here so I decided to make my own. Goodwill is the best place or any used cheap clothing store. I priced a 12x12 piece of wool felt at the craft store and it was almost 5 dollars! Thanks for sharing your thought!
Sunshiine
Nice, they look so cozy, and I do hate when my feet are cold!
You must try this. I do not like wearing 2 pairs of socks to keep my feet warm and that is how I thought of this idea. Thanks for commenting!
Sunshiine
Nice job sunshiine! - and congrats on getting featured :D
