Introduction: Fever Fudge
Inspired by the inventions of the Weasley twins in the Harry Potter books, these two-sided confections are the perfect blend of hot and cool. Eating the red half will cause the heat to rise in your head. Cool the heat by biting into the blue half. This version of Fever Fudge may not affect muggles as strongly as it does wizards.
Stock your own Skiving Snackbox using these candies, some bloody good Nosebleed Nougat, and delightfully nauseating Puking Pastilles.
Step 1: Ingredients
3 cups white chocolate chips
1 can sweetened condensed milk (14oz.)
Red paste, powder, or gel food color
Blue paste, powder, or gel food color
1 teas cinnamon
cayenne pepper--amount varies; 1/2 teas for low-grade fever, 1 teaspoon + for hospital wing
1/2 teas vanilla extract (mint extract can be substituted if you'd prefer a frostier cool side)
loaf pan
parchment paper or foil
spray oil
Step 2: Pan Prep
Line your pan with foil or parchment paper. I lined my pan with a strip of parchment paper in this way to make it easier to take pictures of the process. Grease the foil and/or uncovered areas around the parchment.
Step 3: Bring on the Heat
Place your white chocolate chips in a medium microwave safe bowl. Pour sweetened condensed milk over the chips.
Microwave at 30 second intervals, stirring in-between until the chips are thoroughly melted and the sweetened condensed milk is incorporated.
Pour approximately half of the molten fudge into another microwave safe bowl. Set aside.
To one half of the fudge, add cinnamon, desired amount of cayenne pepper, and red food coloring. Stir to blend in the color. Continue to add red food coloring until the desired shade is reached. You may also want to test spice levels as well. Adjust the amount of cayenne pepper, testing as you go, until you get the appropriate heat level.
Pour red, spicy fudge into the loaf pan. Tap the pan on the counter to level the top and release air bubbles. Refrigerate until set.
Step 4: The Cool Side
One the red fudge is set, warm the uncolored half of the fudge by mircowaving and stirring as before, until the fudge is runny.
Add the 1/2 teas vanilla (and/or mint) extract and some blue food coloring. Stir until the food coloring is mixed in. Add more blue coloring until the desired shade is reached.
Pour the blue fudge over the red and chill until set. The heat from the warm blue fudge should be enough to "weld" the colors together at the joint.
Step 5: Cutting the Pieces
Once fully set, remove the set fudge from the pan. Trim the fudge to make nice squared-off edges.
Slice into long strips. Lay these two-toned strips on their sides and cut into even pieces.
Finalist in the
Halloween Food Challenge
Finalist in the
Candy Contest
3rd Epilog Challenge
1 Person Made This Project!
- Sether231 made it!
40 Comments
5 years ago
what size loaf pan did you use? Also is it ok to use a bar of chocolate cut up?
5 years ago
Does this actually raise your temperature and cause a fever?
Reply 5 years ago
Pls reply starshipminivan
8 years ago
Is it enough cayenne to make ur stomach hurt? Is there another flavor you can add to the blue side to contradict the cayenne taste?
Reply 6 years ago on Introduction
1. no, 2. more mint/vanilla
AWESOME!!!!!!!!!!!!! :D
7 years ago on Introduction
i want to do this, although with different flavorings. i'd do it in a double boiler though.
how would i store it, can it be frozen? do i have to use condensed milk?
8 years ago
This is absolutely amazing!
8 years ago on Introduction
You are literally insane with your favors (and I mean this as a complement)
8 years ago
My friends freaked out ( in joy ) when i gave these to them, they were like; "Who- how did you- how did you make these!" ( by the way they are REALLY REALLY GOOD )
9 years ago on Introduction
These are brilliant! And Halloween is comin' up soon ~ glad I stumbled onto you - it was through your Bacon Cheesecake Brownies, which I will be making tomorrow. I'll let you know ~
Can you make an acid pop sour candy?
Do you have to use gel or powder food coloring? Or can you use liquid coloring?
Liquid coloring is more diluted and the color will not be as deep but you can use it.
Ok thanks.
10 years ago on Introduction
how many pieces did you get from this batch? i would love to make these to take to the anime convention im on staff for this weekend, so many of the other staff members are Harry Potter fans
It makes about 32 good-sized pieces. If you want a larger batch, I suggest you double it and prepare it in a square 8 or 9 inch baking pan.
How do you make the box??????????
It's a small red jewelry box from a craft store. I inked three letter W's on the lid and lined the box with parchment paper before adding the candy.
thts really smart! :D
