Introduction: Fiat Ducato Peugeot Boxer Citroen Relay Van Black Cup Holder
The Fault
Poor design cup holder from factory causing spilt drinks.
Peugeot Boxer, Citroen Relay and Fiat Ducato do not come with an appropriate size and depth cup holder unless selected at factory where it was molded into the design of the glovebox.
The other cup holders in the centre console and door pockets are poorly designed. They are not deep enough causing drinks to fall out, and they are out of reach of the driving position.
Other solutions involve drilling and screwing into the centre console which is costly should it go wrong.
The Solution
The X8R cup holder is a direct fit and can be installed in under 5 minutes
Our cup holder system is designed to fit perfectly in the mechanism of the glovebox. It does not involve any drilling or additional screws. Simply remove the original screws within the glovebox, insert our cup holder and refit the original scews. The glovebox can still be opened and closed.
The cup holder features two open-bottomed holders on the outer sides, allowing taller drinks such as 500ml bottles, sports bottles and large cans. The central cup holder is almost 50mm deep, allowing for drinks to be inserted with no risk of movement and spillage.
The cup holder insert is made from high strength ABS vacuum formed plastic which will not break. Lower quality products on the market are made from cheap foam which leaves a nasty dust/residue in the vehicle and on your drinks.
Vehicles Affected
Peugeot Boxer 2007 onwards
Citroen Relay 2007 onwards
Fiat Ducato 2007 onwards
Associated part numbers:
16 070 885 80, 16 079 396 80
It is suitable for left and right-hand drive models. We offer two styles of cup holder insert: black and grey. Each colour bracket corresponds to the colour of glovebox on the vehicle. They are designed differently as the space within the glovebox is different depending on the colour of dash. Please ensure you order the cup holder insert which corresponds with the colour of your dashboard.
This listing is for the BLACK cup holder.
You Will Receive
1 x Black glovebox cup holder
T25 torx head screwdriver
Step 1:
Open the glovebox and remove the three screws using a T25 torx head screwdriver.
Step 2:
Insert the X8R cup holder insert into the glovebox.
Step 3:
Refit the original screws into the three holes using the T25 torx head screwdriver.
This completes the installation. If you need any further guidance on this install or would like to purchase the parts shown please call us on +44 01843 446643 or email us at sales@x8r.co.uk. Please also check out our instruction guide on YouTube. www.x8r.co.uk Installation is carried out at installers risk, if unsure please contact us or a professional, X8R Ltd cannot be held responsible for any adverse result of installing this product or any injuries caused by install, if in doubt ask a professional. All images and texts are copyright X8R Ltd 2025.
