Introduction: Fiat Ducato Race Van to Campervan Conversion
In this Instructable I will show you my simple campervan conversion from a race van.
Step 1: Clean the Van
Before we start the conversion, it's important to remove first everything inside(seats, matting, etc) and clean the van. Disinfect it if necessary.
Step 2: Measure the Floor and Wall Layout
In this step, we are going to measure the floor and wall layout for the MDF/plywood covering.
We can use carton or insulation foil in tracing the layout and transfer the form to the MDF/plywood before cutting. This MDF/plywood will be the base of our floor.
Step 3: Place the MDF/plywood
Now, we will place the cut MDF/plywood to the floor and walls.
We can use super strong glue and nails/screws in attaching the MDF/plywood.
Step 4: Install LED Downlights
Opps! Do not forget to install lighting on you campervan.
Secure holes for your wires and LED lights.
Step 5: Floor Design
This is optional.
You can make your floor design by placing vinyl/wood tiles on top.
Note: You can skip the areas which are not exposed(e.g under the table/cupboard) to save money... and time!
Step 6: Make a Bed and a Bench
This will depend on you preferences and resources.
You can choose the size and number of your bed and bench depending on your choice and need.
In my case, I chose to build a table that is light but durable and which I can put stuff under it to save more space.
Step 7: Finished!
From race van to simple and spacious campervan.
2 Comments
4 years ago
That looks good! Have fun camping :)
Reply 4 years ago
Thank you :)
