Introduction: Fidget Ring
This is a toy to play with whenever you are bored and it is very easy to make.
All these materials can be found around your house. They are a button, the bigger ring of a key chain, and string. The quantity of the string depends how big you ring and finger are. For the ring you can 3d printed as I did. I prefer the 3d printed ring since it uses less string.
Step 1: The Ring
If you are planning to use a 3d printed ring and you are new to 3d modeling then I would suggest you to use tinkercad to make the ring since it is easy to use. Drag a ring shape from the basic shapes category. Play around with it till you get the size a bit larger then needed. Then wrap the string around the ring until it fits your finger.
Step 2: Button
You can stick the button on however you would like but for it to be long-lasting I say superglue. That's it, Congratulations you have made your ring :) !
