Introduction: Generator - Fidget Spinner Powering 9W Led Bulb 230 V
About: Rotating magnetic fields generator research, electric motor, electric generators, electric vehicles
In the rows below we wish to show how can a powerfull fidget spinner generator can be created. It will generate 100 Volts Ac at the start and it will be able to light a led bulb 230 V 9 W . An educational project, using just a few materials.
Find us ON INSTAGRAM and see a simple electric vehicle - 3 wheels : https://www.instagram.com/sciencetoolbar/
Step 1: Materials :
Materials :
1. fidget spinner
2. coil iron- less - inside syncronous motor 230 V - microwaves and A4 laminators
3. glue
4. bearing ( neodymium sphere 30 mm metal holder)
5. wires
6. three neodymium sphere 13 mm ( extra weight for the fidget spinner)
7. led bulb 230 V 9 W
8. wires
9. plastic holder ( used to fix the fidget spinner generator )
10. voltmeter
Step 2: Operations :
1. fix the fidget spinner plastic holder on a box using glue
2. fix the bearing on the fidget spinner ( 30 mm neodymium sphere metal holder )
3. fix 3 neodymium spheres on the fidget spinner ( extra weight)
4. attach the 30 mm neodymium sphere between poles on the bearing ( the glue one )
5. connect the voltmeter in Ac mode to the coil output
6. connect 9 W led bulb 230 V to the output coil using wires you can use related led bulb 3 W , 7 W also
7. assembles all the components
Step 3: Important
when you are attaching the 30 mm neodymium sphere on the metal holder ( bearing glued on the fidget spinner), fix the sphere between the magnetic poles to obtain the maximum voltage.
a sciencetoolbar project http://sciencetoolbar.com
