Introduction: Fidget Spinner Table
Hello everyone! Today I will show you how you can make your own DIY fidget spinner table! But first of all, I would like to talk about the inspiration of this product and what came along to lead me to this creation. I was getting ready to create a product but one of the hardest things to do is create a useful product that I like and is innovative. With enough research and searching through my own interests I came up with the idea of engineering a spinning table with some material most people have at home. I started to create an idea in my mind and eventually landed a really good product! So next you guys will learn how to do this same product from the comfort of your home!
Step 1: Creating the Base of Your Table
First of all, you will need to create the table of your choice, For this, there's a lot of ways to do this. If you don't have a structure that fits your liking you can laser print a piece of wood to your liking. But if you do have the structure you will use it to create this product.
Laser printing is a good way to create your tables to your size and liking, and you can even add designs like mine.
Step 2: Setting the Fidget Spinner
For the second step, you need to make sure that you do this part correctly, or else the product will not turn or spin once it's all set up.
First of all, you need to take the cap of the fidget spinner that stands on the center you will want to remove it from both sides. make sure you are removing the one where your two fingers would normally hold the fidget spinner and stand as a center of rotation when you spin it.
Step 3: Glue Gun
Once you got your structure and the fidget spinner ready you want to get your glue gun and get ready to piece this all together.
Now that you have this ready you will take the glue gun and the rubber pieces ready to get glued to the fidget spinner. You will take your rubber pieces and stick them to the end of your fidget spinner's corners. make sure you only do one side of the fidget spinner since this will serve as a frictionless base for the table. Once you got this set up you will glue the side without the rubber to the table and let it dry out for a while. Once it drys out your table is done and ready for use!
